Question about Garmin Nuvi 660 GPS Receiver
Won't hold a charge
My Garmin 660 runs out of juice about a half hour into any trip. I keep it in it's holder attached to my cigarrette holder but it is not charging and seems to be using up a charge very quickly. Do you have any suggestions?
  • 2 more comments
  • mermaidgal Sep 12, 2008
    the battery is about a year old, has not been used very often during this time.
    How do I get it open? Where do I buy a batter?
    Right now I have it connected to my PC, prior to this it has just been sitting. Is it charging when connected to the computer? I pressed the reset button and it flashed on fro a few seconds and now is back to showing that it is connected to the computer. What is the 2.7? How do I do that?
    I have ordered a battery and hope that will take care of the problem. Thank you
    President:
  • 1,952 Answers
  • mohammed marika thambi
    mohammed marika thambi Sep 12, 2008
    . Master Dealer of GARMIN GPS 022 6725 0670 / 71. M 098200 53352
    www.carethcorporation.com
    Sergeant:
  • 241 Answers
If you have had it longer than 6months and the unit was in the windshield during the Hot Days
or direct sun light this will kill the rechargeable batteries that are inside.. You can go tho the website and order a replacement battery pack for your GPS... That all>;)
buy.garmin.com/shop/shop.do?pID=31946
your model is discontinued but they will still have the part
Thank you Jayson
Posted on Sep 12, 2008
    Master:
  • 441 Answers
Have you tried upgrading the it to 2.7? You may want Press the reset button behind the GPS antenna and see if that helps
    Genius:
  • 1,142 Answers
May be your charger is not working correctly, try a different charger that will determine the charge and in case you have the same issue then its the battery replace it.
Cheers
  • Garmin Master
  • 13,433 Answers
Hey
How old is the garmin? The battery is probably going bad and would need to be replaced.
  • 5 more comments
  • Ekse Sep 12, 2008
    Try a wall charger for the garmin, you could also contact garmin about the problem, if its under warranty they might offer you a replacement or a repair plan.
    heres the charger
    http://www.buy.com/retail/product.asp?sk...
    If the battery is bad, the charger won't do much good. the battery is build in and is not easyly replaceable the unit needs to be taken apart and the battery replaced by soldering it off the connectors.
  • Ekse Sep 12, 2008
    Seems I was wrong about soldering the battery, seems this model has a easy connector.
    Heres the battery
    http://www.batteryship.com/htmlos/htmlos...
    I'l see if I can find instructions and or a cheaper battery.
  • Ekse Sep 12, 2008
    you can update the unit with the webupdater here
    http://www8.garmin.com/products/webupdat...
  • Ekse Sep 12, 2008
    There was a cheaper battery on Ebay - Click here ebay product
  • Ekse Sep 12, 2008
    Theres a replacement guide available for series 3 and 5 garmins at
    http://www.gpspassion.com/forumsen/topic...
    I don't have a clear guide for your model.
  • Ekse Sep 12, 2008
    You could ask the ebay seller for replacement instructions, he might have some details on that. But basicly:
    1. Unit needs to be opened
    2. Battery needs to be disconnected (2 or 3 pin connector)
    3. Battery needs to be removed from the case
    4. New battery on old batterys place
    5. Connect the new batterys connector (2 or 3 pin)
    6. Put the garmin back together.
    Thats about it.
  • Ekse Sep 12, 2008
    On a final note, If you looked at the battery posted by Kindofcheap, that doesn't fit your model.
    Please see the links I posted for you, the ebay one is the cheapest available and works with your unit.
    Let me know if you need anything else.
    Thanks,
    Ekse
When resetting garmin 660 by holding reset for 2 hr 30 min, does it matter whether it is on or off or plugged into charger?
hi jeff,
im not sure why your holding the power button for 2.5 hours, but any reset should be done while unplugged
now, with the unit off, press and hold the lower left corner of the screen...keep holding ti while you hit the power button to turn it on...keep holding it till you see the screen that asks if you really want to delete all data (this will erase you saved info) select yes the follow the onscreen instructions.
Sep 11, 2011 | Garmin Nuvi 660 GPS Receiver
I've borrowed a friend's Garmin for a trip and when I use the car charger, it doesn't display anything. Once I disconnect, it becomes visible again. I'm going on a long trip and worry. ...
Assuming there is power at the cigarette lighter jack - turn the Nuvi off - then connect the charger. It should display charging battery or charging complete.
If nothing - does it charge with the wall charger? If so check the fuse in the car charger - it's usually in the tip of the charger which can be turned to get the fuse out.
Jul 05, 2011 | Garmin Nuvi 660 GPS Receiver
Cannot seem to get power with cord plugged into cigarrette 12V plug in in truck
Hi and thank you for using fixya:
Please make sure your outlet in your truck is a 12V outlet.
Apply pressure inside and twist while doing it. Some times it is hard to get it in.
Good luck
May 02, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin 660 "Display unit " won't seperate from mount
If you have the suction cup holder in the middle of the bottom of holder there is a tab there... hold gps while thump underneath and press thump upward to release and pull out unit
Mar 13, 2010 | Garmin Nuvi 660 GPS Receiver
How do I turn off our garmin nuvi?
Reset button behind the Antenna, press this in for a few seconds.
Use the Web-updater at Garmin, to update it too,
Jack it to a PC and run the update,
If still playing up, Use the Firmware update at Garmin for it,
(( google Garmin 660 software updates ))
Should be good then
Regards
Richard.
May 18, 2009 | Garmin Nuvi 660 GPS Receiver
My new nuvi 255w will not start displaying info
When using a usb from your computer it is only a trickle
charge to the garmin. Will take a day or two to fully charge. If you use a the cigarette lighter plug that came WITH the garmin, it will fully charge in 4 hours. Stick with garmin approved plugs and all will go smooth. I know, I made the same error.
May 15, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My garmin Nuvi660 is in lock mode and I do not
hold down the button for 2 and a half hours should reset the garmin system
Mar 04, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin c340 FROZE? Here is how to fix it!
My garmin shuts down immediatly when I switch it on. Dont know if there is an internal battery that needs to be replaced or some thing else.
Jan 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
89 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
