Question about Poulan Pe550 Gas Edger
Poulan pe550 edger problem
Iam unable to get my poulan pe550-22cc/711431 type 3 edger started ive installed a new carb. it ran for a while ,than it stalled and i have unable to started again,i blew out the gas lines but no sucess.if i spray starter fluid into the carb.it will run for a second and than it dies."help" thanks for your help, bart(brd9635@aol.com)
Did you adjust the carburetur screws?
Posted on Oct 15, 2008
To change the blade which way does the nut turn to get it off? Clock wise or counter clock wise?
Most weed eaters are opposite to conventional thread. So they are CLOCKWISE to take off
Apr 30, 2016 | Weed Eater PE550 8-1/2-Inch 22cc 2-Cycle...
Is there a video showing how to install fuel line into the gas/oil tank?
I probably can explain this to where you won't need a video.
  1. Remove the old lines noted which is the pickup, which is the return, and the routing. If unfamiliar with line replacement I recommend removing and replacing one line at a time; Also taking pictures if needed helps.
  2. Get a length of tag wire. ( Long enough to pass through the line holes and out the filler opening).
  3. Insert the tag wire through one of the fuel lone holes and out the filler opening.
  4. Cut a taper on the replacement line and insert the tag wire through the tapered section and twist to tie it on the fuel line.
  5. Image of wire/line attachment below.
  6. Now gently pull the new into the tank and out fuel line hole.
  7. The procedure is the same for the other line.
  8. Note: For fuel pickup attach your fuel filter. On return line some have a fitting on the end to prevent it pull out so install the fitting if one is used. Also cut line the line to length adding a little extra for the taper section as needs removing so the line line can be attached.
May 11, 2015 | Poulan WEED EATER PE550 711431 22CC 2 Cyc...
Starts but won't keep going
Fuel issue, carb adjustment and or carb rebuild.
Mar 02, 2014 | Poulan Pe550 Gas Edger
My PE550 weedeater edger that won't stay running. I have new carb, new fuel lines, new starter coil. any idea what could be the problem? I am now checking the gas cap, breather is good
check your fuel lines ensure you have them on correctly also check spark plug clean if necessary also when you change out fuel lines and carb it may take quite a few pulls to crank cause the little fuel system has to get primed up!
Aug 09, 2013 | Poulan Pe550 Gas Edger
How do I change the blade
The blade bolt is normally 9/16, you will need a good socket and long tommy bar to remove the bolt, an impact wrench will take it out very quickly if you have or can borrow one,
Jun 16, 2012 | Poulan WEED EATER PE550 711431 22CC 2 Cyc...
PE 550 Poulan weed eater edger. Replaced gas tank that came with new gas lines and gas cap. Runs on full choke but not off of full choke. Also noticed it will run okay with gas cap off. When you...
A bad duckbill vent (the little green thing) inside the fuel cap will cause a vacuum to be created if it is NOT venting to the atmosphere. Odd that all new ones you have used are bad. Maybe try using your old, original fuel cap and the carburetor needs adjusting or at the least; a gaket and diaphragm kit installed. Carb screws are NOT user friendly, thanks to EPA and CARB emissions regulations. You can get onto the heads of them to turn them by tapping a 22 gauge automotive-type plastic wire connector onto the head, and that will give you enough grip to turn them. I would TRY adjusting the carb before getting a kit, but after 2 years or so, a G & D kit is usually needed due to the internals of the carb drying out. If you adjust the carb, this is how the manufacturer says to:
http://www.zamacarb.com/tipspage.html
Sep 06, 2011 | Poulan Pe550 Gas Edger
Runs on starting fluid, not fuel. cleaned carb with carb cleaner(aerosol) ,still won't run. Primer (purge) bulb doesn't work properly. Spark plug dry, fuel lines clean. Diaphram problem or something...
Try spraying a little gas where you spray starter fluid. If it runs you may have to install diaphram kit. If it has a choke can get around primer not working.
Oct 01, 2010 | Poulan Pe550 Gas Edger
I need a diagram on how to reassemble the pull start.
Complete unit drawings can be found HERE.
On the right side of that page (under the "DETAILS" tab) click the plus sign (+) next to the folder labled "Illustrated Parts Lists".
The page with the pull starter is labled "Engine Assembly Type 3". Click on that and a new window appears with the complete breakdown.
Hope this helps,
Dolf-
Oct 16, 2009 | Poulan Pe550 Gas Edger
Poulan Pe550 Gas Edger Logo
687 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
