Question about Singer 7462 Mechanical Sewing Machine
We have an ancient Singer walking foot machine, model 111W101, that wads a bunch of thread on the bottom side of the fabric. We have been told that the bobbin tension needs to be adjusted. The instruction manual we have says: "The tension on the bottom thread is regulated by means of the screw nearest the center of the tension spring on the outside of the bobbin case. To increase the tension, turn this screw over to the right. To decrease the tension, turn this screw over to the left." The problem is that we can't figure out what screw they mean or where it is. Thank you for your help.
SOURCE: Singer CE-100 Embroidery thread bunches up underneath fabric
I had this problem and it all came down to using the wrong backing. I kep trying to use tearaway on everything but WRONG. Using the proper backing corrects most problems. Good Luck!
Posted on Dec 28, 2007
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
Posted on Oct 26, 2008
  • 19 Answers
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
  • 202 Answers
SOURCE: Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Posted on Feb 11, 2009
  • 128 Answers
SOURCE: thread bunches up under the fabric
For normal everyday fabric, tension should be 3-5.
If it is looping on the bottom, the problem is the threading of the machine. If it loops on the top then the problem is with the bobbin.
Posted on Apr 19, 2009
Machine well not work with the quilting foot what can I do
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
How do I sew denim and heavy fabrics?
Why is my bobbin not winding evenly?
Why won't my machine pick up the bobbin thread?
Why is my machine skipping stitches?
Why is the thread looping/bunching under my fabric?
Why is the thread looping/bunching on top of my fabric?
Why doesn't my stitch pattern match what is on my machine?
How often should I oil my machine?
What types of thread should I use?
I can't see the take-up lever? h
May 17, 2015 | Juki Sewing Machines
Why do stitches bunch when using walking foot on 3 layers of quilting fabric?
make sure that the thread tensions are correct for the thickness of material
remember that only the bottom foot walks and draws the material through so it may need a help and be pulled as it sews.
I find that women in sewing shops just love to talk about problems and how they can help so find a shop and discuss any problems with them
May 08, 2015 | Brother PC420-PRW Project Runway...
I have a singer simple and within only seconds of sewing, the bottom thread will have bunched up 10 times of the amount of thread I would have thought I even used on the bottom side of the fabric
It is in your top threading. Rethread, and with the presser foot up, pull the top thread, it should feed smoothly, now put the presser foot down, the thread should barely move. This should seat the thread in the tension discs. Good luck
Dec 10, 2010 | Singer 3116 Simple
I have a singer CG 500 C. When switching to a different fabric or thread, the bobbin thread begins to get loose and bunched underneath the fabric. I have adjusted the tension to have it get better for a...
Your threading might be the problem, follow the advise in your manual for your fabric. or go to & see what they advise in your model or another one for tensions on satin. You may need a walking foot to do the job, You can take a scrap piece of fabric and try using tissue paper under your fabric to stop the slippage, then tear it away. We did that when I was learning to sew, and it worked. Good luck.
Sep 12, 2010 | Singer 5050 Mechanical Sewing Machine
I have a Singer Sewing Machine 5817C, the thread bunches under the fabric while sewing. I have tried adjusting all the switches so that I just get a standard straight stitch, but it bunches up on the...
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
Oct 14, 2009 | Singer Sewing Machines
Keeps "birdnesting", besides rethreading, how do I fix?
when you have bunching on the bottom, you have a problem with the top thread: no tension. (and visa versa) Make sure the thread runs through the tension discs, these discs are activated when you put the presser foot down, so you want to thread the machine with the foot up, also feel if there no burrs, hooks, or whatever, so your top thread comes smooth off the spool, no jerking.
May 24, 2009 | Singer Sewing Machines
Singer Simple model 3116
If you bought this machine at WalMart, I recommend you return and the go to JoAnn Fabrics. Walmart can buy millions of these machines and pay next to nothing for them. I don't even suggest a beginner buy this machine.
Dec 08, 2008 | Singer 3116 Simple
Oct 30, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer 7462 Mechanical Sewing Machine Logo
48 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
