Question about Amana Refrigerators
Compressor change
I am going to change a compressor in an Amana Refer.and I need to know what is the best way to do it,also need to replace the rear roller. thanks Bert
    President:
  • 1,462 Answers
This is not a diy job. after replacing compressor, you have to vacuum down the system ie remove all air and measure the amount of refrigerant injected into the system. you need special gear for this
Posted on Sep 13, 2008
2003 Cadillac coupe DeVille . Diagnostic code RIM C0655. Where do I start?
DTC C0655
Level Control Compressor Relay Malfunction .
You start by doing the diagnostic tests for that code .
Circuit Description
The automatic level control adjusts the vehicle suspension ride height. The RIM determines the height of the vehicle based on the voltage from the automatic level control sensor. The RIM grounds the compressor relay and the exhaust control solenoid to raise and lower the vehicle in order to keep the vehicle level.
Diagnostic Aids
• Inspect all wiring harnesses carefully for chaffs and proper routing. Refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
• This circuit is monitored before every functional operation of the compressor relay output. If a compressor relay fault is detected, the RIM retries the output every 15 seconds to try to recover from the fault.
Your probably not going to be able to do the factory diagnostics unless you have a factory scan tool to turn on an off the relay . You can test with a volt meter at the relay for B+ voltage and control from the RIM - Rear Integration Body Control Module. Do you know what a relay is and how it works ?
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, command the level control compressor relay ON and OFF.
Does the level control compressor relay turn ON and OFF with each command?
YES Go to Diagnostic Aids
NO Go to Step 3
Turn OFF the ignition.
Disconnect the level control compressor relay .
Probe the coil side feed circuit of the level control compressor relay with a test lamp that is connected to a good ground.
Does the test lamp illuminate?
YES Go to Step 4
NO Go to Step 10
Connect a test lamp between the control circuit of the level control relay and the coil side feed circuit of the level control compressor relay.
With a scan tool, command the level control compressor relay ON and OFF .
Does the test lamp turn ON and OFF with each command?
YES Go to Step 8
NO Go to Step 5
5
Does the test lamp remain illuminated with each command?
YES Go to Step 7
NO Go to Step 6
6
Test the control circuit of the level control compressor relay for a short to voltage or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES Go to Step 13
NO Go to Step 9
7
Test the control circuit of the level control compressor relay for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES Go to Step 13
NO Go to Step 9
8
Inspect for poor connections at the level control compressor relay . Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES Go to Step 13
NO Go to Step 11
9
Inspect for poor connections at the harness connector of the RIM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES Go to Step 13
NO Go to Step 12
10
Repair the coil side feed circuit of the level control compressor relay . Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
YES Go to Step 13
11
Replace the level control compressor relay.
Did you complete the replacement?
YES Go to Step 13
12
Replace the RIM. Refer to Rear Integration Body Control Module Replacement in Body Control System.
YES Go to Step 13
13
Use the scan tool in order to clear the DTCs .
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Aug 04, 2017 | Cadillac Cars & Trucks
After cleaning frige and plugging it back up it blows air but not getting cold I can here what I think is the thermastat clicking on and off
You are most likely hearing the compressor overload device tripping and resetting as the compressor is probably not starting. remove the rear lower panel of the unit and verify your possible buzz/click is coming from the compressor. If this is the case you can replace the starting and overload device to see if this fixes the issue, if not your compressor may be in need of replacement. Pleazer Appliance...
Apr 18, 2014 | Amana Refrigerators
Balky compressor on pro style refer, alarm going off intermittently
That sounds like your start relay/capacitor needs replaced. The clicking is the relay.
Jan 23, 2012 | Maytag Refrigerators
Amana abb2224dew repairman installed part # 8201786. This was to replace the compressor start up. Worked for a week, then same buzz click sequence occurs. Looked up part number. Part is for mostly...
The replacement compressor kit is #12002633 from Amana (Now Whirlpool).
In this kit are the following New model compressor, relay/capacitor, jumper and instructions.
Kenmore does not make appliances rather all of the other manufacturers produce for them.
That part number is for Whirlpool Start Relay/Capacitor and as long as the compressor is the right horsepower for the relay it makes no difference who made it. (Techumseh or Embraco)
Apr 29, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana ABB222DE is the overload/capacitor the same thing as the compressor relay? I just had the compressor relay replaced in amana bottom mount. Frig cools fine but every 2 days or so buzzing noise...
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana ARS2365AC Refrig. Noise from under refrig. Refrig getting warmer inside. It clicks like a switch is trying to turn on them gives off a high pitch hum for about 30 seconds. I have made sure that it...
first thing to check is the timer,remove the bottom kick plate,on the left side you'll see a knob,if you can turn it by hand turn it slowly or use a screw driver and turn it until it clicks,it could be stuck in defrost,if the compressor runs then you need to change out the timer.if nothing happens turn the timer until it clicks again.now go in the rear of the machine,unplug the fridge,remove the bottom rear panel and you'll see the compressor,there's a start device on the compressor and they do fail.remove the clip and before you remove it look and see where it clips on to,so when you have to put it back on or replace the part you know where to clip it again.slide off the start device,shake it,if you hear a rattling noise like a piece is broke off inside it or if it smells burnt this is your problem,the part number is W10189190 and it's like 20 dollars.when you call your parts store,give them the model number off the fridge and give them the p number and they will make sure the part number i gave you is correct.now from what you are discribing it sounds like the compressor isn't running,is this correct?and the machine is getting warm.when you change out the start device and if the compressor still doesn't start then you have a bad compressor and most likely you'll need to change out the machine.let me know what you find
Mar 20, 2011 | Amana Refrigerators
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
5 year old Amana bottom freezer. No cooling because compressor not working. Technician tried a starter but it short circuited. Now fridge is off. Worth buying new compressor or a new frig? Is this a...
you can have the compressor replaced for around 500usd on the norm. that would be the most inexpensive way to go compared to a new unit , it will come with a 90 day-1 year warranty.
Phil
Jun 10, 2009 | GE GTH18KBR Top Freezer Refrigerator
Buzzing noise near compressor on an Amana refer. PARB1917CSO
I can help , It was the relay , they can blow when they experience a hard start , by replacing it and having the same issue this means the compressor is locked up , they sell a booster for this that can sometimes free the compressor up , its called an rco410 , this part will be your only chance to get your compressor going again. let me know if you have any other questions and tell me how it works out.
Phil
Jan 07, 2009 | Amana ARB1917CSL Bottom Freezer...
Refrigerators Logo
63 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
