Question about Kenmore 83142 Electric Dryer
Timer issue just had new timer installed. timer side of drying options works great. dryer wont shut off when on non-timed side (towels, regular, damp, etc) it goes right by the off, and continues on to the timed selection HELP!!!!
    Genius:
  • 1,239 Answers
Hi The dryer timer, located in back of the control panel, controls several things: the drying time of the clothes in the drum, the flow of electricity to the heating element, and the flow of power to the timer motor and the drum motor in the dryer cabinet.
Timers are driven by synchronous motors. Although the contact part of the timer can be cleaned and adjusted on some dryers, this is a job for a professional repair person. Timer motor repairs should also be handled by a professional, but you can replace a faulty timer yourself. Here's how to test and replace a dryer timer:
Step 1: To access the timer, remove the front of the control panel. On some dryers, the timer can be removed without removing the panel. In either case, pull the timer knob off the shaft and slip off the pointer. The pointer is usually keyed to the shaft by two flat surfaces to keep the pointer from slipping when it's turned.
Step 2: Test the timer with a VOM set to the RX1 scale. Turn the timer to the NORMAL DRY setting and disconnect one of the timer power leads. Some timers may have several wires connected to them: The power leads are usually larger than the other wires, and this size difference can be spotted under close examination. Clip one probe of the meter to each timer terminal. If the meter reads zero, the timer is working. If the needle jumps to a high reading, the timer is faulty and should be replaced. Replace the timer with a new one of the same size and type.
Step 3: To replace the timer, have a helper hold the new timer close to the old one, especially if there are several wires to be changed. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram detailing the proper connections. After all the wires are connected, check the connections again for accuracy.
Posted on Sep 12, 2008
Maytag atlantis dryer wont shut off. changed the timer and it still wont move.
send the model number.if this is electric try this.put it on air fluff and start it,if it has heat your element is bad,it's grounding out,part of the element is touching the metal case around the element.if it just did this on auto i would say change the cycling thermostat but on timed dry it just counts down like a clock.i saw this once and the element was bad,grounding out.it was tricky i thought it was the timer also.
Nov 27, 2017 | Maytag Dryers
The dryer does not pass 6 min mark and does not shut off. How would I test a humidity sensor? Thank you for help.
A dryer moisture sensor can stop working without notice, until you notice your clothes being over dried or still wet at the end of the cycle. It is a good practice to test the dryer moisture sensor periodically. There are two types of moisture-detecting sensors for dryers. Once you understand how they work you will see how to test each one.
1. Sensor BarThese sensors contain digits that protrude outwardly. They work on an electrical current and the moisture from the clothing.
The first step to test is to place completely dry clothes in the dryer and turn on the dryer; it should run for a few moments and then shut down right away.
Secondly, place damp clothes into the dryer, turn on the dryer and watch the timer. As the clothes begin to dry the timer will move and shut off.
2. ThermostatThe timer is regulated by the thermostat. The thermostat rests in a closed position. To test this type of moisture sensor, place damp clothes in the dryer. Watch the timer; as the clothes begin to dry, the thermostat should open and the timer will move forward ,eventually shutting off.
Sep 08, 2013 | Dryers
How to clean sticky keys on my asus x54c hb01
A few non intrusive ways can be done.I'm not familiar with your model, but a "regular" keyboard actually can be rinsed off with the sprayer at your kitchen sink. Use warm water, no cleanser, or chemicals! Then shake the daylights out of it from all sides. If the sun is shinning, then put it in the sun for several hours to dry. If that won't work, turn on the oven to bake, & set at the absolute lowest level. That is usually 170f. After the oven has cycled 2 or 3 times, shut it off & quickly place the keyboard in the oven, keys down! & shut oven door. After 3 hours it should be dry. Re-connect to PC, voila!
A quicker remedy, but could be a bit messy so you'll need some paper towels, simply spray wd-40 at the "problem area". (it doesn't take much) Be sure to immediately clean off excess from the keyboard. wd-40 will not dmg electrical circuits, it actually cleans & helps dissolve water & chemical based liquids. Use a damp soft cloth or paper towels. Hope this helps!
Feb 08, 2013 | ASUS Computers & Internet
My Amana Model NDG5800AWW dryer has ceased to dry clothes dependably. The Only setting that still sort of works is HIGH timed drying, and this heats up to what used to be the "delicate" setting....
if you are using the auto dry setting and the dryer is still running after 5 hours you either have a timer issue or a thermostat problem.
The timer is driven by a motor, if the timer motor is bad the timer wont time out.
in the auto dry cycle the thermostat has to cycle off and on which then sends power to the timer again advancing the timer.
set the timer in a timed dry cycle for say ten minutes, if the timer advances and turns off then you know the timer works. if it doesnt advance you have a timer motor issue,
if the problem is the auto cycle, you could replace the thermostat, about $20 american. however a clock timer would be cheaper.
Based on how old is your machine and do you want to stick a timer in it after already paying the service man is up to you.
A basic bath towel load should be dry in about 50 minutes, this varies on how good your seals are and how long a vent you are running, if the dryer vent was plugged you already have shortened the life of your heating element.
Sep 22, 2008 | Amana Dryers
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Kenmore 83142 Electric Dryer Logo
266 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
