Question about Minolta bizhub 200 All-In-One Printer
Bizhub 200 malfunction c2257 - how can we fix this? at first we encountered paper jam, then after solving the paper jam, c2257 came up. pls help thanks
    New Friend:
  • 51 Answers
shut help
Posted on Sep 03, 2009
  • 24 Answers
Are you sure it is not 2557 as 2257 does not appear in the manual.
Posted on Jun 25, 2009
5 Suggested Answers
SOURCE: paper jammed problem 13.05.00 JAM INSIDE TOP COVER
It happens form both: manual feed and tray... sensors don't look misplaced.
Posted on Jan 17, 2008
SOURCE: Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Posted on Jun 05, 2008
SOURCE: PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Posted on Jul 22, 2008
darck_teck
  • 22 Answers
SOURCE: BizHub 250 Malfunction Code C2557 - HELP!
ok il start by saying that my english is veryyyy bad.
ok so the developer is guarantied for 80000 copies but i seen 200k with a new dev. (developer type dv310) after some of the developer is lost in the copying proses the ac-dc sensor detects that the concentration is rong and it shows the C2557 error thats wen the error is shown by the copier . solving it is simple you can replace the dev. and run F8 mode if it dosent work manually ajust the acdc to a lower value (lower value means that is les tonner in the dev. hyer value more tonner obviously ) , 0r leave the old dev. in it and ajut the acdc to about 180 (you can ajust to 180 take out the tonner botle make some black copies(30) and put back the tonner bottle and adjust to a lower value that works) . The problem can also apear if the copier docent supply tonner so check that first . Entering the service menu is simple pres utility > (toch screen) original size> (kepad) stop>0>0>stop>0>1 the password from the manufacturer is 00000000 , in the service menu select tech mode in ther yowl find the different start modes F8,F... , and you have printer select printer and acdc adjustment , pres C to clear the value and via keypad enter the desired value . THE REST IS UP TU YOU MY FRIEND . CAUTION IF YOU DONT HAVE ANY IDEA ABOUT A LASER COPIER DONT EVEN ENTER THE SERVICE MODE CAUSE YOU CAN DO MENY WRONGS IN THE COPIER . GOOD LUCK
Posted on Nov 10, 2009
HOW TO REMOVE THE PAPER TRAY
To remove the paper tray draw 1 or2 or 3or 4 on the right side of the draw you should see a single screw it holds a small metal lock remove it and the slips all the way out.
Mar 20, 2014 | Minolta bizhub 200 All-In-One Printer
Bizhub c220 tray 1 problem
pull out tray and check any paper is jammed is remaining at the back end of that tray
Nov 19, 2012 | Konica Minolta Bizhub C220 Color Copier
Paper jam on display but there's no paper jam
Then the roller are dirty or need to be replaced because they cant grab the paper so the machine is miss feeding jam is when the paper hit something or stop electrically move to different draw or the by pass
Jul 25, 2012 | Minolta bizhub 200 All-In-One Printer
There is a paper jam
The solution depends on which type of printer and which model it is. Generally, you must open the access door/compartment and try to get the paper out. I had a bad paper jam last week and I had to open the access door (same access area you use to change out the ink cartridges) and do a lot of pulling and maneuvering. Don't force the paper too much or you might break the printer.
Mar 06, 2011 | Kodak Office Equipment & Supplies
Bizhub 200 Copier: Copier says malfunction...
if copier is saying malfunction, then look it will also showing the code, note the code then inform me...........
May 16, 2010 | Minolta bizhub 200 Copier
Minolta bizhub erorr codeco202
CO202 relates to tray 1 (top tray). It hasn't managed to lift the paper successfully.
Open the tray, remove the paper, reset the machine (open/shut front door) then reload the paper and try again
Hope that helps
Regards
Taminol
Jul 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C350 Malfunction Code C-0510
I have this malfunction code, C-11A3, coming up on my Konica/Minolta Bizhub 350 copier/printer. Anyone know what it is? I don't use the techs, because they charge much I don't pay for the service anymore-seems like most things should be able to be fixed by the owner. I needed help for this code
Mar 21, 2009 | Konica Minolta bizhub C250 All-In-One...
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
Mar 29, 2008 | Minolta bizhub 200 All-In-One Printer
Minolta bizhub 200 All-In-One Printer Logo
257 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
