Question about Evesham Voyager 5700 Notebook
Evesham Notebokk I've got an Evesham Notebook Laptop, it goes straight into suspend mode as soon as I switch with the crescent moon sign flashing, does anyone know a cure??
  • yousaf_is Nov 30, 2008
    my evesham laptop heats up and turns off, sometimes it will work for hours.
Why does my mobile phone not ring when someone calls me. It goes straight to message centre
You may have accidentally turned on Do Not Disturb mode. In the top right corner of the screen, is there a tiny icon that looks like a crescent moon? If it's an i-phone, go to settings, and in the second group of items, make sure that Do Not Disturb is turned off.
Jul 09, 2017 | Cell Phones
Have msi lap top vr601x model when try turn on by power button a half moon icon on keypad flashes on with the power button then after 3 sec turns off what does this mean
the half moon indicate an sleep mode when you open your laptop the sleep mode is already activated thats why it goes to shutdown reason is your sleep mode key is grounded try to consult it to your your dealer
Sep 17, 2009 | MSI VR601 Notebook
Flash player don't work?! please help.
Sorry, but your question is confusing: Flash Player is an Adobe product which allows online video streaming. Your DSC-V1 is just a camera and neither has nor needs Flash Player.
Perhaps you're confusing it with the camera flash used to provide light when taking photos? If the flash is set to "on" it should usually pop up and fire except when the camera is set to certain scene modes (see below). The other flash settings are "off" (no lightning flash icon) and "slow" (the letters SL appear next to the lightning icon). The only other icon which can appear next to it to the left are the scene modes. These only appear when the mode selector dial is set to "SCN" and there are six of them: beach mode (palm tree and beach icon); snow mode (snowman icon); portrait mode (a pair of heads and shoulders icon); landscape mode (mountains in a picture frame icon); twilight portrait mode (crescent moon and a head and torso icon); and twilight mode (crescent moon icon). Of these, only the last one prevents the flash from firing even if switched on.
You can learn more about these by clicking this link to the Sony website which has a downloadable .pdf manual. The scene modes and what they do is explained on pages 63 & 64.
I hope that you've found my answer to be of use and in return ask only that you return the favour by rating my answer. If your problem remains unresolved then please explain clearly what you'd like to know in a comment and I'll try again: I've been using a DSC-V1 regularly since 2004 so there's not much about it which I'm unfamiliar with.
Jul 16, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Handmade
"Every Crescent Moon snowshoe is hand made in Boulder, CO" says their website.
http://www.crescentmoonsnowshoes.com/
Dec 02, 2008 | Crescent Moon 15 Backcountry Snowshoe
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba power led flashing yellow
This flashing LED usually means only two things, both are quite harmless:
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
good luck.
No display here...
hi, when the laptop batt goes down it will switch to power save mode, the moon that that u see is the power save standby mode, u will have to wake up the system using the wakeup key on the keyboard or hard reset will do.. let me know
Jan 14, 2008 | Acer Aspire 5050-3242 Notebook
Evesham Voyager 5700 Notebook Logo
146 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
