Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool fride model # ed25dqxbw00
My water dispencer tube broke and parts are no available. I would like to disengage the water dispencer. How do I do that?
  • butchf Feb 24, 2009
    Water to fill up ice cube tray does not shut off automatically. What a mess to my carpet.HELP
5 Suggested Answers
BNewberry
  • 93 Answers
SOURCE: whirlpool side by side water dispencer
Sounds like some switch wires at the water valve.
Should be color coded.
Posted on May 15, 2008
  • 27 Answers
SOURCE: no ice in the icemaker
there may be some problem with water inlet solenoid valve. the coil or valve could be faulty
Posted on Mar 10, 2009
milten1
  • 1304 Answers
SOURCE: water freezing in ice maker inlet tube
yes exactly,
follow your tube down to the water vavle you probaly have a small leak in the solonoid and it is dripping up
hard to beleive but it is
you can also turn down your freezer just a bit
but you will find the replacement water valve at the
www.appliancepartspros.com
just type in your model number
Posted on Nov 04, 2009
Testimonial: "Well written response. Doubt was anticipated which made next test exactly the right one to confirm the problem. A link for the solution was provided."
  • 2516 Answers
SOURCE: on an whirlpool side by
it looks like it pops off.go to this site,put your model number in and look at dispenser front.use a thin screw driver or a putty knife,the face part pops off then the part behind it has screws in it.copy and paste this and look up your machine.http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-ED25CQXHW02/1198/0165000?pathTaken=&prst=0&shdMod=ED25CQXHW02
Posted on May 19, 2011
I have a water/ice dispencer in the door of a side by side Whirpool model no. GS2SHEXNT00. The water dispenser leaks, sometimes a large run of water other times just a drop. I took the front cover off the...
Heat from the night light will deteriorate the plastic tubing of the dispenser. Cracks in the tube will allow water to go out the side of the tube as well as in the glass you're filling. There are repair kits available from online appliance parts companys.
Apr 10, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
On an whirlpool side by side fridg model ED25CQ XHW02 how does the ice/water dispencer plastic cover come off?
May 19, 2011 | Whirlpool ED5FTGX Side by Side...
Icemaker stopped working
It can happen that the ice got too thick for the little auger and it snapped off. The other issues arise when the water inlet tube freezes up so no water gets dispenced into the ice maker.Defrost unit to check this out. At least 24hrs.
Sep 15, 2010 | Whirlpool Refrigerators
What is the part called (the little flap that closes after Ice comes throught the dispencer?
it's called an "ice chute door". Look on sears.com, select "Parts Direct", another page will come up, enter your model number of your frig, then enter, wait a few then your model info will pop up, select either the freezer door or if it has "Ice & Water dispencer" select it, wait for another page to come up, then look thru diagram for part you are looking for, then scroll down to that part number and you will be able to see actual mfg part number. There should be a "Ice Chute Repair Kit" listed as that is how they come. Search internet for best price.
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker and water dispencer
Check the water inlet located at the back of the fridge.
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 21, 2009 | Whirlpool ED5FHEXMQ Side by Side...
MY WATER IS ALWAYS DRIPPING..HOW CAN I FIX IT?HELP
you may want to check your water presuure if pressure is to low the valve in the back of the fride is not closing properly or the valve is defective to check for this you need to remove the electric solenoid behind the fride leave the water line installed disconect the output tubingif it drips replace the solenoid valve gilles_dumais@hotmail.com
Mar 15, 2009 | Whirlpool ED2FHSS Side by Side...
Whirlpool side/side ice dispencer not working
I had the same problem, however, the ONLY fix was to call the repair guy and get a new part. I took it out, defrosted the unit thinking ice was in the gear mechanism, lubricated and re-installed it to no avail. The repair guy had SEVERAL of these geared mechanisms in his truck so that told me THIS HAPPENS A LOT. Good luck.
Aug 13, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refridgerator ice maker
Check your water valve. Most likely it is leaking by the seal on the icemaker side of the valve so that it is getting a slight trickle of water all the time to the fill tube. This will freeze in the tube much like an icecicle is formed. This is the most common cause. Low water pressure and mineral deposits inside the tube can cause it also, but it usually will take longer than a few days for the problem to reappear.
The dispenser housing and parts on your fridge are replacable and show to still be available.
You can go to sears.com, click on parts, enter your model number, and see parts diagrams and lists for your fridge.
This link should go directly to the parts site.
http://www3.sears.com/
Post back and let me know about the water valve.
Thanks/Mike
Jan 06, 2008 | Refrigerators
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
415 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
