Question about Maytag MBF2256H Bottom Freezer Refrigerator
Fridge is leaking water all over the place. - Maytag MBF2256H Bottom Freezer Refrigerator
  • 3 more comments
  • zeak47 Apr 07, 2008
    My kenmore hotspot refrigerator is leaking from the inside right underneath the freezer, there is way water drain into the frig.
  • danmcgav Apr 10, 2008
    drip tray inside my fridge is constantly over flowing. not sure where the water goes when its working or how to make it go there.
  • nadort May 03, 2008
    water leaking from freezer. have had problem for a while. ice builds up under ciols in top causing drain to freeze. have to take apart and defrost. it says clear for a little while then freezes again. is there a fix for this? it is a beach house that is rented.
  • oscar55 Jul 06, 2008
    hose got loose from the freezer , and water is not going in to the ice maker
  • rockymtnhigh Jul 16, 2008
    Me too - ice builds up
    under coils in top causing drain to freeze. Tool it apart and
    defrost. one week later froze up again. Any suggestions?
The defrost drain opening or drain hose is plugged up with ice or crud. If the drip pan is bone dry, it's a sure sign that the drain opening or drain hose is clogged. Trace the drain hose back to see where it pick up the condensate in the refrigerator cabinet. Remove whatever pieces you need to to clean that sucker out. Door gaskets are torn or not making good contact with the cabinet. No? Well then where's all that water coming from, Einstein? It can only come from the humidity in the outside air--your fridge can't make water, dontcha know
Posted on May 10, 2006
    President:
  • 3,130 Answers
Have you shut off the water from the ice maker to see if it stops?? if it does then its a leak in the hoses or valves. Has the fridge been moved latly?? Sometimes when peeps move a fridge the drain hose comes out of the drippan to catch the defrost water. And Yes the fridge does make water from it self defrosting . All self defrosting fridges do!! Good Luck
Fridge always has water all inside of it. I mean on the shelves, under thr drawers. I need to dry it off all the time, otherwise the water will come out. What should I do? What is the problem?
Thank you,
Vane
Posted on Apr 18, 2008
I had an issue with water occasionally appearing on the floor. It was very randon. I added a piece of tubing to extend the drain tube to the evaporator pan. I have not had the problem since.
Posted on Jan 12, 2008
I had a problem with condesation forming from the humidity in the air and it was constantly filling the drip pan and overflowing. The service person put an add on evaporator coil above the drip pan to stop the build up of excess water. It solved the problem.
Posted on Sep 19, 2007
The pan that the defrost drain hose drains into on our refrigerator had a small 1/8" hole in the front bottom corner of the pan and when the defrost cycle activated the water just ran into the pan and out the hole and onto the floor.
Posted on Jun 09, 2007
My refridgerator leaks
either there is a pub hole in the giving on the ein or our just is not tightened enough at the connection. is there water ay the bottom if the fridge cause usually there is so reservoir to keep water cold ay the back boutin of the fridge. youre going to have to look for water and follow the trail. remember water cant flow upwards so lllllll for the leak above the highest place you find water
Jan 08, 2012 | KitchenAid Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
It leaks water from underneath
If the water is coming out from under the fridge and you have a water dispenser or automatic ice maker, then I would suggest that you pull the fridge out from the wall and check the water tubing going to the back of the fridge. The tubing is connected with a compression fitting (a special nut that compresses the tubing to the fridge. There may also be a few more pieces of tubing on/in the back of the fridge with these fittings. Place you fingers on each fitting to see if it is loose or wet. If you find a wet or loose fitting, take some pliers and tighten it (snug it up, but not too tight because you can damage the fitting. Dry up the water. Watch the fridge for a while to make sure the leak is stopped. If you can't get it stopped, or if it gets worse, you can cut off the water (there should be a valve under a cabinet next to the fridge, or under your sink). You can get a replacement fitting at Lowe's2_bing.gif and they can tell you how to install it if necessary. If you have water pooling under your fridge and it goes up to the wall, then you should check on the other side of the wall for water also. This happened to our fridge, but we did not see the water in front of the fridge because it ran to the back of the fridge and under the wall into our carpet on the other side. Wet carpet is how we discovered the problem.
May 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking water from the actually fridge over the floor.
manually fully defrost unit,clean all vents /drain pipes
make sure door seals touch all round(no air gaps)
use bicarb to freshen interior and dry as best you can
then switch on and hopefully,if unit is working normally,enjoy...only place cold food in fridge to minimise ice build up.(some fridges have a drain vent in the centre bottom of door to allow water to drain when defrosting
Feb 14, 2010 | Refrigerators
Samsung RL33SBNS FRIDGE FREEZER LEAKING WATER
I HAVE HAD THE SAME PROBLEMS WITH THIS FRIDGE FREEZER-THE ENGINEER WHO CAME TO FIX IT SAID THAT SAMSUNG STOPPED MAKING THIS MODEL BECAUSE OF THE PROBLEMS WITH IT- THE ENGINEER REPAIRED IT BY DEFROSTING IT WITH A WALLPAPER STREAMER AND ALSO SAID HE CUT OFF A PIECE OF THE RUBBER TUBING WHICH CARRIES THE WATER THROUGH THE DRAINAGE SYSTEM BUT HE COULDN'T TELL ME WHY IT DID THIS IN THE FIRST PLACE
Mar 22, 2009 | Samsung Refrigerators
My ice and water dispenser is leaking
I am not an expert on refrigerators, but generally you hook a 1/4" (copper or plastic) line to a solenoid valve to the back of your refrigerator, which you then hooks up to a filter, which then ties into an existing compression fitting, or saddle tap on a cold water line (usually on the kitchen sink). Some refrigerators have a place for a filter to fit which runs to the cold water, and not an exposed rear solenoid.
Sep 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Leaking water tank
My fridge is leakin water so I need to find out where the water is coming from ?
Jan 16, 2008 | Maytag MZD2766GES Side by Side...
Water leaking from bottom of refriderator
dear ricurtsmith..
your fridge has a water trap pan underneath it to catch the water from the drain line when your fridge automatic defrost.
either the pan is not in place proper or the pan may not be underneath, period. or pan could be stopped up/need cleaning. or if pan is made of plastic, it could be cracked.
it is located at the bottom of fridge where you see something loos like a grilled vent. remove that bottom piece to get to the drain pan.(it just slides out!!) good luck & hope i was helpful.
brbharo....
Dec 05, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
Older maytag fridge side by side.
Buk, there's supposed to be a drain pan under your fridge to catch the water that comes from the drain tube. The water that's coming out is supposed to be there (only, it's supposed to be caught by the drain pan)... it's the water that's made when your fridge defrosts itself. If you plug the tube, the water will back up inside the fridge , puddle up in the bottom and eventually leak out through the door.
You should order a drain pan for it. Here's a link to one online. After you have it in place, you won't have to worry about it anymore. The water that collects there will simply evaporate back into the air.
Oct 15, 2007 | Maytag MZD2766GES Side by Side...
Maytag MBF2256H Bottom Freezer Refrigerator Logo
3,578 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
