Question about HP iPAQ RX3115 Pocket PC
Will not work with battery
My 3115 is not working with the Battery. When I have it in to charge the lights do not light up or nothing. I tried to use the sync cable to have it on while the battery is in there and it still does not work. When I turn it on with the battery in it the light amber light blinks twice and than it goes off and repeat the process until I unplug it from the computer. Do you think I need a new battery.
  • giotate Nov 06, 2008
    Thanks, that was the problem. It works just fine now.
Its the battery. Do a hard reset and if that doesn't fix the problem, then its time for a new battery.
Posted on Nov 06, 2008
Why won't my car start? no lights interior/exterior.
It seems that the battery is incapable of holding a charge. You might try disconnecting the battery cables and try charging the battery again over night. Reconnect and see if anything works - if nothing works - it's time for a new battery.
Apr 10, 2015 | 1996 Jaguar Xj Series
Tried to install a headlight modulator in a 2011 Triumph Sprint GT. now I have no power whatsoever, battery drained replaced with a new battery and still no horn, lights, or power
It sounds like another fuse is blown or possibly a relay. Check all of them, if none are bad, then make sure your battery cables are good, use a test light to check them. Its more then likely a bad relay though. Good luck !
Apr 13, 2014 | Motorcycles
My battery is fully charged all lights are working radio is playing and door chiming, but when I turn the key absolutely nothing happens. It done this two days ago and even though the battery was charged a...
Do the dash lights go out when you turn the key, If so then have the battery load tested, With a bad cell in the battery all lights and radio will work,( only a small draw on the battery) but when a heavy draw as in starter the battery will fail.
Oct 04, 2017 | 1987 Nissan Pickup
MH-25 is not charging the battery
Check the cords and make sure to disconnect and then reconnect the cords. Try the charger if nothing then try replacing the battery. If the battery is bad the charger will not work. If the battery is replaced and will not charge then replace the charger.
Mar 26, 2013 | Nikon MH-25 Charger NIKON
2000 pathfinder battery draining
Sounds like your alternator is doing nothing-the car is running only off the battery. Have your charging system checked-does your battery light stay lit? If that bulb is burnt out, that may be why the charging system is not working. On some charging systems, that bulb is crucial for the alternator to work.
Engine off, a fully charged battery should measure 12.5 volts with a voltmeter. Engine idling, and the voltmeter at the same battery should be showing about 13.5 volts. This tells you the charging system is working.
May 13, 2017 | 2000 Nissan Pathfinder
My 2008 maxima is completely dead.. the intelligent key wasnt working so i switched the battery.. tried using the metal key to turn the ignition and that wont work.. its locked up and wont unlock.. nothing...
Have you checked the battery at all? you may have just left the lights on and flattened the battery. Try charging the system first, and check the underhood fuses. situated near the battery. Hope this helps.
Mar 10, 2011 | Nissan Maxima Cars & Trucks
Turn key nothing happens windows work interior lights works thats all
try old syle boost,car to car with booster cables,inside lights will work even if battery almost dead,just try to boost it off or pull battery and have it charged,autozone or advance auto will charge for free.but have to take battery to them out of car,or if you have charger at home,let it slow charge overnight on low charge. thank you for choosing fixya.com
Dec 31, 2010 | 1998 Pontiac Bonneville
Does not switch on and there is no orange chg.light or green ligh
Your' battery may be bad, have gotten disconnected, or the battery is dead, and the charger is bad.
Dec 29, 2008 | Sony DVP-FX810 Portable DVD Player
Toshiba laptop power light on but not working
Try this.Your VGA is problem or your battery is fully charge down.so please fully charge your battery atleast 8 hours and then press your power switch.it will on your loptop system.
plz Call 09944377607 V.RAJA
Jul 25, 2008 | Toshiba Satellite A135-S4527 Notebook
HP iPAQ RX3115 Pocket PC Logo
413 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
