Hi, I took my camcorder out yesterday, and it will not work. the tape will not eject, play, fast forward, record or rewind. The red light next to where it says camera just flashes, as if there is an error ( this light usually stays on /not flashing\ ). Also because of this, I cannot access the on-screen menu. Could anyone please offer some help? Thanks, Burnsie #53
Comments:
May 10, 2006
- thanks! ill go and do that now, that advice is top class. Regards, Burnsie #53
-   my cam will not eject it flashes red with auto off unloading lock
can you help . Have done hold eject when powering up but still no luck.-   Guest
I had the same problem with my camcorder. I removed the battery for about 3 days and when i turned it back on it worked. is there a battery in camera to keep the time and date? maybe it is in safe mode and by removing power for long enough it will reset itself. paul sa
Its the tape is stuck or the mechanism is jammed or the small pan caps have started there demise of your camcorder.. Inside most camcorders there are small surface mounted capacitors made by panasonic and they all I say ALL will leak one day and when they do its not just the cap thats bad but if left unattended it will eat up the Printed curcuit traces on the pc board. Have the unit looked at right away by a camcorder expert and see if its too late to save the board. Good Luck
The number of flashes represents the fault code - for example - F03 ( Fault Code 3 ) will flash the red light Three times and then rest and the again three times. I'm chasing fault codes- but thought that you could move your enquiry forward by counting the flashes. ..
Hope that helps a bit - Greg
Was this helpful?
Yes
No
Solution #4
posted on Jan 14, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i found to get the tape out alight whack should do it then it works fine
i have panasonic dv cam... connected to pc via firewire... how to use it as web cam in yahoo...
(More)
i have panasonic dv cam... connected to pc via firewire... how to use it as web cam in yahoo messenger
my camcorder is dead it just stopped turning on. i need the tape out of it is there a release Model...
(More)
my camcorder is dead it just stopped turning on. i need the tape out of it is there a release Model PU-GS12 I used the camcorder, the next day it was dead I went to best buy to purchase a AC power supply and that didnt work now the camcorder is dead. Do they just die.
