Question about Honeywell Heating & Cooling
I have had a new honeywell humidifier installed. The problem is the control H8908B. HE INSTALLED IT FIRST TIME ON A DUCT RIGHT NEAR THE FURNACE AND IT FEEL OFF . Melted . Then came in and moved it away from the furnace but still on a heat vent and the same thing happened 2 days later. It appears that it should go on a return duct upsream from the humidifier. Can it also be mounted on a wall. By just felling the ducts when the furnace is on can I tell which is the return air duct ? Thanks for your time and as you can tell I am not very mecanical Jim Phelan
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
After the air leaves the fan ,this is called supply air ,before the air enter the fan which sucks air into the fan --- on the flter side --is called the return air!
Posted on Sep 13, 2008
Wire Honeywell HE220 to N8MPN/L, *8MPN/L furnace control board
HI
I have similar isssue with HE220 but in my case the water run through all ththe time, even when unplugged from the power outlet.
Would that be solenoid issue?
the unit run fine for last season so the wiring is fine.
Any ideas would be greatly appreciated.
Jan 22, 2012 | Honeywell HE220A1019 Whole House...
I don't think our h8908b honeywell humidifier is working. The house seems pretty dry. Kids are complaining of dry noses and throats. I have also been pretty dry nosed. How do I know if it is working? And...
Hello, if there is no water draining out of the humidifier than it is not working, The humidifier should turn on and off with the furnace, The best thing to do is have the humidifier tuned up by changing the water panel, making sure the there is voltage present the the solenoid valve, and making sure the water supply is getting to the solenoid valve. Let me know if you have any further questions I will be glad to assist you.
Feb 07, 2011 | Honeywell HE360A1027 Whole House...
Can the humidifier's housing for a Honeywell model HE265 By-Pass Humidifier be installed on the return air duct, or must the housing for this model always be installed on the hot-air supply duct just above...
Hello Which came first the chicken or the egg?The unit will operate perfectly in the supply OR return as I have installed in both.If there is more room & easy service access put it in there.
Sep 14, 2010 | Honeywell Humidifiers
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Have a Honeywell House Humidifer - Control Malfunction?
get a humidity gauge from radio shack for about 20 bucks. thats the only way to tell. or pay a service compant tocome out for probaby a 100 bucks to tell you what the humidity level is in your home. id get the $20 one a the shack
Dec 02, 2009 | Honeywell Power Humidifier: Furnace...
Two furnaces one humidistat help on wiring
Honeywell tech support is awesome here in Minneapolis, I think you need seperate humidistats but check with HW, number is in owners manual.
Nov 21, 2009 | Honeywell Power Humidifier: Furnace...
Water keeps running to Honewell 360A Whole House Humidifier
You may need to replace the valve that is wired to the furnace that controls the water flow
Feb 01, 2009 | Honeywell HE360A1027 Whole House...
Wiring problem
Sounds like you may have put 120v through a 24v solenoid and humidistat.
Is the HUM terminal on the furnace 120v or 24v?
If it is a 120v terminal you will need a 120x24v transformer and a new solenoid and maybe a new humidistat.
Dec 19, 2007 | Honeywell HE360A1027 Whole House...
Humidifier intermittently won't shut off with blower
THAT MODEL COMES WITH A BUILT-IN AIR FLOW SWITCH (IF I RECALL CORRECTLY) THAT CAN GO BAD ... IN THE OLD DAYS WE JUST POWERED THE HUMIDIFIER BY CONNECTING IT TO THE LOW SPEED (FOR HEAT) OF THE BLOWER MOTOR. HONEYWELL HAS HAD PROBLEMS WITH THEIR RESIDENTIAL AIR-FLO SWITCHES ON HUMIDIFIERS AND THEIR ELECTRONIC AIR CLEANERS. AND THEY ARE THE HIGHEST PRICED ON THE MARKET.
Oct 27, 2006 | Honeywell HE360A1027 Whole House...
Heating & Cooling Logo
94 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
