Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag dishwashwer problem
Thanks for responding, but I am talking about a dishwasher and what I am thinking is this is a pump issue.
Could a cracked impeller that is working cause no water to come out of the top arm?
Water is coming out the the lower arm, but not very strong. I'm assuming that there is a hose in the back of the unit, but what I'm not sure about is whether a bad pump that is pumping to the lower arm could cause no water from the top.
    Genius:
  • 1,239 Answers
Hi try this In most dishwashers, the water pump is located under the lower sprayer arm. This component pumps the water through the dishwasher. The pump has two impellers, top and bottom. These, as well as other components, can become clogged with food or detergent. Here's how to disassemble the pump:
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Posted on Sep 12, 2008
Why doesn't it work?
Dishwasher Diagnostic Touchpad is Not Working,Maytag ...
? 8:28
https://www.youtube.com/watch?v=zex_g2TJRl4
Aug 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Maytag Built-in Dishwasher which has this following issues: Touchpad System Is Not ...
Maytag Dishwasher Repair - Will Not Start or Complete a ...
? 5:06
https://www.youtube.com/watch?v=cfWUeh0ZtPY
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Built-in Dishwasher which has some of ... Dishwasher Diagnostic Touchpad is NotWorking,Maytag,Whirlpool ...
Top 638 Complaints and Reviews about Maytag Dishwashers
www.consumeraffairs.com > Homeowners > Dishwashers
Rating: 1.2 - ‎185 votes
Can't push a button to choose what cycle I want, it doesn't respond. .... After 2 1/2 years the control panel on my Maytag Dishwasher will not work. This is the 4th ...
Maytag Dishwashers - ConsumerAffairs.com
My dishwasher just stopped working 1 year after purchase. .... Holding Control Lock or Delay for 3 seconds doesn't seem to clear the circuit board logic. Problem ...
Dec 12, 2015 | Maytag Dishwashers
I have an E39927 Type 776-0 dishwasher. The problem began this week, in that water does not fully drain from the dishwashwer following the end of any of the washing cycles. The unit seems to be...
disconnect the drain hose from under the sink. place it into a bucket and put the dishwasher to drain. if it drains in the bucket fine then you know you have a problem with your drain. if it doesnt drain, then the problem is most likely the drain pump
Oct 23, 2011 | Maytag Dishwasher
My maytag dishwasher won't drain. It is not clogged. It just won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Jan 31, 2011 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwashwer stopped cleaning dishes properly. Powder detergent was not clearing the dispenser (even after 2 runs). Strange burning smell emitting. Ran again completely empty on Auto Clean, even stronger...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 26, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
No water is coming into the dishwasher. What should I do?
I will have to assume the dishwasher turns on when you press the start button.
Very hard to provide solution without knowing the make and model of the dishwashwer.
Possible causes of water not coming when dishwasher program has commenced are-
1. water tap is not turned on.
2. the water inlet solenoid in dishwasher is faulty
3. the float switch at base of dishwasher (depending on model) is triggered and thinks the dishwasher is already full of water.
Happy to provide a specific solution if i know the details. Please post a comment.
Jun 13, 2010 | Dishwashers
Maytag dishwasher has a grinding sound during the
Hi
Many times a complaint of noises ( grinding or scraping ) can be traced to a cracked impeller in many of the common motor and pump assemblies used today. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
The motor shaft has started to rust and swells out and this swelling cracks the upper impeller. Most times a new seal and impeller kit can cure this complaint but sanding and cleaning of motor shaft is required before replacing the new seals and impellers.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Bosch dishwasher sgs43c02gb cycle problem.
I found the problem for pump noise & water in bottom. The dishwasher hose connection under sink had small plastic piece stuck in narrow elbow
Jan 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
GE PDW9700 - Heating Element turns on by itself and Burns my dishes
have experienced this problem on some zanussi machines. what is happening is that the machine continues thro cycle thinking there is water in machine when there is not. can be caused by:
slow pump rate caused by blockage especially near the drain pump inlet
faulty pressure stat
Aug 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
256 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
