Question about Warrior 797146022002
Usb not recognized
I OWNED A TOSHIBA LAPTOP (SATELLITE A-135) MY ENTIRE MACHINE WAS WORKING FINE UNTIL ONE DAY ALL OF THE U-S-B PORTS STOP RECOGNIZING ANYTHING. THIS IS REALLY A BAD SITUATION BECAUSE I NEED THE PORTS FOR MY EVERYDAY WORK. I KNOW THEY ARE NOT BUSTED BECAUSE I CAN STILL PLUG MY CELL PHONE AND CHARGE. WELL I HAVE TRIED TO ERASE THE PORTS FROM THE DEVICE MANAGER AND NOTHING, THE REGISTRY AND NOTHING, FORMATTING AND EVEN THE FAMOUS TURN OFF AND UNPLUG THE ENERGY SORT IN FACT I LEFT IT WITHOUT POWER (WITHOUT THE BATTERY) FOR THREE DAYS AND NOTHING I DON'T KNOW WHAT TO DO PLEASE HELP ME
    Novelist:
  • 126 Answers
Try to load the BIOS defaults. Tap F2 when you turn it on. On the system setup screen, press F9 to load defaults. F10 to save and exit.it might not work on vista but u can try this
try uninstall and reinstall the USB driver. Start Menu>Control Panel>Device Manager>Universal Hub Controller, right click the driver and then click uninstall. then restart your computer so that it may reinstall your driver. Toshiba laptops in the past have supplied only about 100ma (rather than the 500ma usually available) at the USB ports. (That's to make the battery hold its charge longer.)I definitely can not guarantee that a powered hub will solve the problem. You might make arrangements to borrow one.try and perform allthe steps above and try and reinstall the operating system also if still it doesnt work then definately replace the motherboard or take it to the local technician and tell him to replace the motherboard......hope this will work
Posted on Jan 27, 2009
Usb port won't recognize mouse
the usb port may be damaged or bad solder connections, do a system restore taking the it back before the problem occured. "long shot"
Mar 19, 2012 | Toshiba satellite c660
I have a toshiba satellite laptop A135 series and it won't recognize my toshiba external hard drive. However, the drive works fine with my HP
This can be an issue with the USB port, or the drivers.
Is the hard drive a Power HDD ? that means it has 2 usb chords one for power and one for data transfer? coz those might not work with laptops, also has it ever worked with the laptop ?
Thanks
If this was helpful, then kindly rate me.
Nov 10, 2010 | Toshiba Satellite A45-S121 Notebook
I have a toshiba satellite A-135 laptop that will not recognize anything plugged into the usb ports
Check to see if one of the USB ports is damaged. Sometimes they can be damaged and have connections touching the outside metal of the port which actually grounds the connection and will cause the other ports to not work either. If it is connected then use a flat tip screw driver (*with the machine off and battery out*) to make it not touch the outside of the usb port and try "other" USB ports that aren't damaged and see if it works. If it doesn't then you are looking at needing a new motherboard. Locate your closest ASP and take in for service, you can find them at support.toshiba.com.
Nov 15, 2009 | Toshiba Satellite A135-S2276 Notebook
USB ports not working. Any ideas?
In that case ,
Click on start and run
Type devmgmt.msc
Then uninstall all devices under universal serial bus controller.
Then need to click on any option in the list and scan for h/w changes.
This will install all devices back and your system will be able to recognize all devices now.
Hope this help.
Cheers!!!!!!!
Jun 21, 2009 | Toshiba Satellite A135-S2276 Notebook
My usb flashdrive is not recognized on any of my usb ports on my Toshiba satellite m35x-s163, can you help?
Test usb port with another device,
check in my computer for the drive,
Test usb flash in another Pc,
Manufacturers website for a possible driver.
if still not working then it's faulty,
Regards
Rpf
Apr 14, 2009 | Toshiba Satellite M35X-S163 Notebook
I have a toshiba satellite a135 s2276. The usb ports are all enabled but it won't recognize any device plugged in Also when i boot up the screen is kinda pinkish in color then goes black. Everything works...
The problem is with your harware. Either there is some problem with your USB ports( Mother Board) or its due to conflicting drives. Reinstall all your USB port drivers.
Mar 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Wireless mouse and usb game controller
It is faulty. Something internal is broken. I feel the only way to remedy this is replacement, sorry. I have seen this many times.
Oct 24, 2008 | Toshiba Satellite M45-S165 Notebook
Toshiba satellite a135-2326 usb not recognized
its a driver issue most likly down to vista (as always) have you tried the latest updates from the microsoft website yet?
Aug 11, 2008 | Toshiba Satellite A135-S2386 Notebook
USB Ports Not Working
Check Device Manager for bad drivers
Aug 09, 2008 | Computers & Internet
Check your CMOS settings to ensure that your USB ports are enabled.
Oct 15, 2007 | Toshiba Satellite A135-S2276 Notebook
Warrior 797146022002 Logo
Top Warrior Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Daniel Dollive
Daniel Dollive
Are you a Warrior Computer and Internet Expert? Answer questions, earn points and help others
