Question about ASUS P5LD2-VM Motherboard
Chassis error pops up all the time
Something about a hardware Chassis error. How do i fix it?
    President:
  • 2,351 Answers
Hi JJCEO, please open your motherboard manual to page 1-33. Add a two pin jumper as noted. This should stop the chassis error issue. If you do ot have your manual. You can download it from Asus by clicking on this link; http://support.asus.com/download/download.aspx?modelname=P5LD2-VM&SLanguage=en-us
Mike
Posted on Sep 12, 2008
We receive 43 redundancy failed hardware failure and second controller seem to be in idle stat please suggest what is actual problem
Here is explanation from HP manual how to fix that problem:
43 Redundancy Failed Hardware Failure
Type: Error
Description: While either attempting to enter redundant mode or already
operating in redundant mode, one of the controllers encountered a hardware
failure on the communication channel between the two controllers. Redundancy
is disabled at this time.
Action:
If the storage system is currently involved in host I/O:
1. Remove the standby controller.
2. Wait 10 seconds.
3. Reinstall the controller, and be sure that it seats fully in the chassis.
If this action does not solve the problem, wait until downtime is available and do
the following:
1. Power down the storage system (on page 28).
2. Remove both controllers.
3. Reinstall both controllers, and be sure that they seat fully in the chassis.
If this action does not solve the problem, contact HP support.
Sep 11, 2013 | HP MSA 500 G2 High Availability Kit...
Nautilus t912 Treadmill Breaker Pops
see the diagrams attached and you must test for to isolate the short.
the short can be a) power cord short b) outlet wall faulty with ground test and repiar c) ground to chassis. d) filter short e) power switch short f) coil or transformer faulty. and step on until you elminate the short USE the DVOM or VOM. g)motor h)board main
Before to do something RUN THE software calibration for diagnose, troubleshooting, and fix it.
God bless you
Jul 26, 2012 | Exercise & Fitness
I have this error :0x88113eaa please help me thanks
Hi there..regarding with that error message..it is something to deal with the print mechanism of your psc printer..and i believed that the carriage of it (the one that is holding the ink cartridges) is not removable. most of the time if that error message pops up then it is a printer general error or in other words it is a hardware failure..
May 29, 2011 | HP PSC 2355 All-In-One InkJet Printer
912-the computer has been removed.the machine cover have been removed since
Make sure you close the case cover first before performing the steps below
1. Go to BIOS by pressing F10
2. Select hardware monitor setup and enable the reset case open status ANOTHER SOLUTION IS
1.turn on ur PC.
2. press F10
3. wait 10 sec.
4. press "right arrow" 1 time
5. press "enter"
6 press the "+" sign on ur numeric pad
7. press F10
8. press "enter"
May 22, 2011 | HP Compaq Presario SR2011WM PC Desktop
How to fix error 512 for evo d310 I replace chassis, rear chassis, or front chassis fan but still error I wont to fix it not show any error thank
Error 512 is a common Windows error. Error 512 is usually caused by missing system files, wrong system settings or a corrupted registry file. Run a registry scan to check for registry errors & other system problems. 90% of the time this will fix the cause of the error.
Optimize PC programs might do the trick, some are free to download.
Jan 13, 2010 | HP Compaq Evo D310 PC Desktop
My A4TECH PK-636MA WEB CAM WON'T WORK AFTER INSTALLATION
remove all previous web cam drivers from the pc ...
reinstall the driver ...and after you plug it ...let the wizard to search for the driver and do something that seam like reinstalling second time ...
if it will gave you some errors for missing files (example: missing dll.d50 or something like this ) just click browse and locate the file manually from the installation cd ...or from the folder where is installed it depends...sometimes I dont know why ...just do not see some files...maybe its something about compatibility ...or ...OS )
if after this is still not working ...see maybe is not a webcam that will work with your operating system ...some dont work on vista ...or windows 7 ...
Mar 19, 2009 | A4tech G-Cube Cosmo-tini notebook webcam
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Nokia 6300 mic problem
u just have damaged its earpiece and buzzer or u just forgot to move it from ur older middle section to the newer one
May 01, 2008 | Nokia 6300 Cellular Phone
Popping noise
Does the " popping" noise come through the speakers or from the TV chassis ? If it is coming through the speakers you could have a bad solder joint somewhere in the tuning circuit. If it is a snapping sound coming from the chassis, then you probably have something arcing in the high voltage circiut. If this is the case then you should have it checked out since this can cause other parts to short shutting down you set completely.
Jan 21, 2007 | Hitachi C25-RF35S 25" TV
ASUS P5LD2-VM Motherboard Logo
278 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
