Question about Dryers
CREDA TCR2 TUMBLE DRYER
I have a creda TCR2 Tumble dryer. It is starting to make a sreeching,
rubbing noise. It seems that the element is rubbing on the back. I have took it a part and had the back plate off slightly and the noise stopped.
When replacing back cover noise came back
Any advice?
Thanks in advance
    New Friend:
I have no heat coming from the dryer
Posted on Jun 11, 2013
Put it in the bin
Posted on Sep 12, 2008
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
How do i change the element in a t522vw creda dryer
http://www.ehow.com/how_2087872_replace-belt-creda-tumble-dryer.html
May 28, 2011 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Creda tumble dryer T632CW is not heating up. Any
SOUNDS LIKE YOU NEED NEW HEATING ELEMENTS.
Oct 18, 2009 | Dryers
Not heating up
Hi
If your dryer doesn't heat, check these:
Power from the house -- Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element -- Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse -- On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring -- A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 07, 2009 | Dryers
No heat to tumble dryer
Check the thermal disc with an OHM meter. One will be next to the heat element (high limit) and another on the air exhaust area which is the low limit.
Dec 16, 2008 | Dryers
Dryers Logo
834 people viewed this question
Top Dryers Experts
