Question about InFocus ScreenPlay 4805 Multimedia Projector
No pwer to Infocus sp 4805
The projector does not power up. Is there a fuse I can change? How can I troubleshoot the power supply? Thanks
  • ernielucas Sep 29, 2008
    We were in a party last night and am supposed to show a Powerpoint presentation using my 4805. After making the connections, when the 4805 was powered on, there was a spark/smoke at the point where the power cable touches the DVI cable - it burnt the cover exposing the aluminum coaxial. (FYI, we did a dry run of the presentation in a different location and there was no problem). The laptop then failed to start and the 4805 turns on (you could feel the fan) but the lamp is off as well as the LED.
    We tried looking for a fuse thinking it was burnt and we couldn't find one. The manual and drawings also do not show any fuse anywhere. Can I still save my 4805?
My 4805 made a loud pop noise and smoke and died.
I thought it the bulb and wasted $340 on that purchase.
They are subject to overheating and the main circuit board may be fried.
It cost me $50 for a tech to confirm my suspicons of the same.
Look at the main circuit board and you might idenify a scorched
overheated area.. My shop told me you can purchase a new main
board.. Diagnosed by no power to the bulb...
Posted on Oct 13, 2008
Screenplay 4805 not anything. I plugged it in, heard a pop, and then tried to turn it on, and nothing happened. No fan, no light. Could this be a fuse?
Yes, it could be the glass fuse on the power supply/ballast. If you remove the top cover you should see it clearly if it has blown.
Aug 06, 2010 | InFocus ScreenPlay 4805 Multimedia...
I need power supply for infocus 4805 screenplay
You shold buy 520-0143-00 ECA, POWER SUPPLY, X2 Use if S/N contains an A in the fifth from the right digit "AMMxxxxA0000" 520-0126-00 ECA, POWER SUPPLY, X2 Use if S/N contains a zero in the fifth from the right digit "AMMxxxx00000"
cost about $90
May 23, 2010 | InFocus ScreenPlay 4805 Multimedia...
How do i find out if i need a new lamp for my infocus 4805. when i turn it on the fan blows for a cpl secs and the green light blinks a few times, but i dont get anything saying the lampis out
when you power it on, do you hear a high-pitched whir? if not, you need to replace the colorwheel. it's also the colorwheel if you hear a buzzing instead. if the colorwheel does not spin, the lamp won't come on. if the colorwheel is ok, check the lamp. is the screen on the side of the lamp clogged with dust? is the inside of the lamp bulging, spotted, or foggy? if so, replace the lamp and clean out your projector with canned air. dust blocks air flow and keeps in the heat. this shortens the life of your lamp and projector. if you do need the colorwheel replaced, you could get the part from an infocus service center and do it yourself, or send it in for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 27, 2009 | InFocus ScreenPlay 4805 Multimedia...
Random and unusual fan noise
give me a mail adress so i can send you. i have a website its turkish but guide is english i downloaded it
waiting fo you
May 29, 2009 | InFocus ScreenPlay 4805 Multimedia...
My bulb went out on my infocus sp-4805. I bought a new bulb, and replaced it, and it worked...for five minutes. the picture went out, and it was overheated. I took some parts off, and sprayed can air in...
The fan is probably on it's way out and cannot produce enough air flow to cool the lamp. Replace the fan with the same ratings as the original and it should work fine. The only other thing would be a problem with the power supply not supplying enough power to the fan, but, a bad fan is more likely.
Feb 24, 2009 | InFocus ScreenPlay 4805 Multimedia...
Replacement parts
No, I still have not been able to find the parts. No one has responded to my question as to where I can get them. Any help would be appreciated. Thanks.
dcabbarno2@aol.com
Jul 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
Projector will not power on
Check your cooling solution wether its a fan malfunction or if it needs a new fan - or h20 cooling system
if not its either the power supply or something serious - send it to manifacture or go to a in-store repair
(it could be the dust protector)
Nov 16, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
222 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
