you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the
4:3 mode.
Full mode
Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display
anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the
16:9 mode.
Zoom mode
Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for
letterboxed and
open matte video.
14:9 mode
Main article:
14:9
In
14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode
Wide Zoom mode, also called
Just mode,
Horizon, or
Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of
Full mode.
thank you for ur help i was just about to crack the bad boy open but i guess i should allow a professional to take a look at it thankss!
tv only showing black and white picture. But blue screen when you turn the tv on
