Question about Sony Handycam DCR-PC101E Mini DV Digital Camcorder
Tape is stuck in my Sony handycam DCR-PC101
I've tried all the troubleshooting steps... turned it off, removed battery, turned on with eject button pressed, pressed the reset button, left the tape compartment open for an hour..... nothing seems to work. any help would be appreciated.. thanks
  • 3 Answers
I have managed to eject my tape by powering 4.5 V the little motor which drives the eject mechanism.
Problem is that you have to dismantle half the camera to do this (be very careful with the flexy wires they are fragile) and I wouldnt' do it without the service manual.
Posted on Dec 24, 2008
    President:
  • 3,130 Answers
If you turned on the power or inserted the battery while pressing the ejct on the camcorder then you have a serious mechanical control curcuit fault or a power supply thats bad inside the camcorder. Probably those small surface mounted pan caps that ALWAYS go bad. It time to take the unint to a pro to be checked unless you have all mthe speacial tools and extenstion cables to work on this camera. Good Luck
Posted on May 10, 2006
Sony dcr-pc9 ejects tape when trying to load....not a claening issue..common symptom on this model
Try this:
1. Turn off the Handycam
2. Remove the battery from the Handycam.
3. Remove the AC Power Adapter from the Handycam.
4. Move the Handycam power switch to the ON position.
Note: Leave the switch in the ON position for at least 15 seconds.
5. Move the Handycam power switch to the OFF position.
6. Connect the AC Power Adapter to the Handycam.
7. Turn on the Handycam.
Apr 05, 2011 | Sony Handycam DCR-PC9 Mini Digital...
Sony camcorder HDV 1080i model HVR A1U won't eject tape. Deck lid opens but compartment (tape) won't come up. C:32:11 flashes.
Sony A1U stopped functioning. Neither AC power or battery yields anything. Reset button yields brief flash only. Tape stuck in machine. Help?
Feb 22, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Nov 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Cassette won't eject
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
Aug 13, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Can not eject
Aug 11, 2009 | Sony Handycam CCD-TRV318 Camcorder
Manual eject option for trv320? No tape in it. Won't open so I can put one in.
Aug 06, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony Model DCR-TRV350 Tape stuck in camera.
take out the battery, put it back, turn it on and you take the tape out of the camera. hope this helped you. have a great day.
Mar 03, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony Handycam DCR-PC101E Mini DV Digital Camcorder Logo
483 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
