Question about Dell Inspiron 1501 Notebook
Can i remove the battery?
So u mean to say i can still use my laptop even if i remove the battery..because i have the power chord is that wat u mean?
    Novelist:
  • 116 Answers
Yes you can. The idea on a laptop is that the battery is only used when there is no other power source (AC power cord). When running on AC power, the laptop will also charge the battery.
It's actually good fashion to remove the battery when only using AC power for long periods of time. This will reduce chargings on the battery from normal power loss (all batteries lose power over time). One thing to do for sure is battery maintenance. This is easily done by simply running the battery dead and then giving it a full charge. This gives the cells in the pack a "stretch" if you want to put it that way. However, it's definitely able to be removed while on AC power.
One good thing about running the battery inside the laptop on AC power is; it acts as a UPS as well. The laptop can switch to the battery if the power fails or whatnot. :)
Not stepping on anyones shoes here, just thought I'd add some information.
Posted on Sep 12, 2008
  • 2,794 Answers
Yes.
  • Tim Babcock
    Tim Babcock Sep 12, 2008
    I'm hoping you can rate these comments too for me.
Stuck in sleep mode
remove the battery and unplug your power chord for 1 min. then plug your power chord back in and try to turn it back on.
if it works then plug your battery back in and see if it boots your system up without the power chord.
if everything works fine then go into your control panel and change your power options.
Feb 12, 2014 | HP Pavilion Dv7-4065Dx Laptop Lcd Screen...
Hello MY HP laptop 4520s i3, turns off or restarts when i cut power adapter from him .can somebudy halp me for my problem
It's sad to say that your laptop battery pack needs a replacement or a technician to fix a hardware problem in there. How it happens it turn offs when you remove the power plug from it, battery pack are rechargeable so when you are using your power chord it means you are charging it also. Hope it helps you.
Jul 05, 2011 | HEWLETT-PACKARD ProBook 4520s
Cq50 laptop touchpad random issue
Remove the battery and the power chord and press the power button for about 30 seconds. Then place the power chord and battery and turn on the system.
Sep 04, 2009 | Compaq Computers & Internet
Power chord problem
(1) Does the machine work with the cord plugged, if so it is the battery or the charger circuit at fault
(2) If it does not work then there is either a break in the cable where it enters the plug which plugs into the back of the laptop or the power supply has failed
Aug 31, 2009 | Sony VAIO VGN-NR430E/S NoteBook
Hi, I have a compaq C740TU laptop. I am not able to switch on my laptop with battery alone...when i connect the power chord to my laptop, it doesn't get the power for sometime ... but after sometime...
remove yhe battery then check it if it starts normal then the battry is faulty but if problem persist with power then repair the motherboard
Jul 16, 2009 | Computers & Internet
I HAVE A LAPTOP ACER AND THE POWER DOES NOT TURN ON
It could be a battery problem. Try switching to AC mode by plugging in to an AC outlet using your Acer power chord (battery charger also). If the charger led don't light, it means it's defective and it can't charge your battery. Please try another power chord or battery charger then. Just remember to take out your battery when using your laptop in AC mode to lengthen your battery life. Regards!
Jul 05, 2009 | E-Machines eMachines Desktop PC
My nb100 doesn't turn on.. can you help me?? even if i remove the battery and i just plug the charger chord.. it still won't turn on..
Make sure the light on your ac adaptor is lit when you plug it into the wall outlet so this way you know that the ac adaptor is working properly. If you do get an led to show up then try again, if you still don't get power to the laptop then take out the hard drive and dvd drive from the laptop and try again. If you still don't get power then for sure the motherboard is bad cause that means the voltage is going thru it properly.
Jun 06, 2009 | Toshiba Computers & Internet
Dell 620 Battery Issues
Chances are pretty good that your battery just needs to be replaced. Over time all rechargeable batteries loose their ability to hold a charge. It's also possible, but less likely, that there could be an issue with your AC power adapter or the charging circuitry inside the laptop.
Best bet would be to find a similar laptop with a battery that does charge and switch. If the problem follows the battery then you need a new one.
Dec 19, 2007 | Dell Latitude D620 Notebook
Dell Inspiron 1501 Notebook Logo
95 people viewed this question
Alun Cox
