Question about Dell UltraSharp 2000FP 20.1" Flat Panel LCD Monitor
Dell 2000FP monitor black screen
I just got a used Dell 2000FP. It worked pretty well for a few days but now it works only intermittently. The power button stopped working. Now I have to turn it on by plugging it in. Then all the lights on the front come on and stay on and the power button light is both orange and green at the same time. Pressing the power button or any other buttons has no effect. The DEll logo appears on the screen but the monitor usually won't accept a signal from my laptop. My suspicion is that the firmware needs to be reloaded. Is that possible? Sometimes I plug it in and it just works, but that is increasingly rare. Thanks. -Loren
  • 1 more comment
  • ollie598 Apr 20, 2008
    My Dell 2000FP is doing the same exact thing. I would be glad for any ideas or solutions. I have tried it on a few different computers. Worked fine a few days ago. then it started doing this.
  • PetitCarrion Feb 01, 2009
    hi!!!! did you repair your monitor? how???? one friend give one and it works exactly like you explain!!!!
  • Blauelf Feb 07, 2009
    Same problem here. Last week, the monitor freezed after some minutes but kept working until I changed screen resolution (as long as the adjusting to the current resolution was finished at the time of freezing). Now it freezes during startup procedures.
  • 3 Answers
I just fixed my Dell 2000FP LCD monitor and right now using it.
The solution is very simple and easy. Do it your self if you are comfortable soldering.
Resolder the 2 transformer legs ( 9 legs each transformer), 2 oranger capitors, 2 small green capitors, 2 inductors coil legs.
Use at least 45 watts soldering iron with a pointed tip. Be careful.
Roan
Posted on Apr 17, 2009
  • 5 Answers
This problem is, without a doubt, caused by the firmware inside the atmel chip (AT49BV8192AT) that is located on the main logic board. My 2000FP had the sam problems, It just freezes during startup and only a hard reset could solve the problem. I also tried capacitors and re-soldering stuff then it seems to help but this is not the case because the problem is in the beginning intermittend. After a while it freezed all the tim during startup. It is the firmware that is slowly getting erased. I ordered a new atmel chip with pre-installed 2000FP software and used a Hot air gun the repace it. The monitor has been working for half a year now. This is a typical DELL 2000FP problem from a certain series.
Good luck repairing.
Smokkeltje
Posted on Aug 18, 2010
  • Robert Monroe Jan 05, 2012
    Smokkeltje, how did you acquire the atmel chip with pre-installed 2000FP firmware?
    Problem Solver:
Hey there.
I got the same problem just right now and figured out by the most profesional technician (My Edgardo) that u only need to solder the cole, both of them a little bit more, and thats it!
try and update me.
cheers;
Posted on Apr 06, 2009
The main logic board has gone bad and requires physical repair, take a look at http://www.lcdrepair.us/2000inverter.html
(it's not firmware or the power supply)
Posted on Apr 27, 2008
    President:
  • 3,130 Answers
Sounds like a bad power supply. I doubt if its the firmware as where did it go?? Did you dump the puter?? have you tryed the monitor on a friends puter?? Good Luck
Posted on May 10, 2006
My monitor died slowly, the time to the freeze constantly degrading. No difference if the device was warm or cold. This leads to the following hypothesis:
Microprocessors freeze up because of three reasons most times: First, temperature problems. Unlikely here. Second, programme runs into an infinite loop because of poor code. Unlikely, too. Third, the supply voltage is not as stable as it should.
So it is most likely a problem of the power supply. Since the external power supply is fine the problem will be the internal DC/DC converters providing the 2.7V for the logics chip. Their maximum current output is heavily dependent on the condition of the electrolytic capacitors involved. And these tend to run dry over years, especially when stored in hot places (and a running monitor might be such a place).
If I am right you need to find the degraded capacitor(s) and exchange it with a new one, SMD, Low-ESR, 105°C temperature rating, capacity and maximum voltage as printed on the case (first number is capacity in µF, second is maximum voltage). Process involves SMD soldering, so practice soldering and dissoldering on a cheaper board first, not the no-longer-produced 4-layer one.
I will try this myself once I have some spare time (have to finish my diploma thesis first).
Posted on Feb 07, 2009
My monitor is a dell 2000 flat screen 20.1" turns
This is a backlight problem. The picture is there but there is no light from behind the LCD screen. It could be due to faulty capacitors, which are easy to replace. It could be a faulty Inverter transformer, which is harder to fix but he backlight controller board can usually be replaced at a reasonable price. If you have soldering experience you may be able to replace the faulty capacitors - look for capacitors with bulging tops.
Repalcing the inverter board in a job for someone with electronics experience. You can buy a universal inverter board for about £15 to £20 from e-bay.
20 inch monitors can be bought for about £100 to £150 so you need to decide whether it is economical to repair.
Feb 18, 2011 | Dell UltraSharp 2000FP 20.1" Flat Panel...
It is not so difficult to repare if you have scills to open the monitor and scills in un-soldering/soldering electronic components, than yes it is worth it, but if you go to a shop they have a tendency to sell you another monitor since the price they charge to repare the powersupply is about the same as a new monitor
Auxilliary monitor on Dell Latitude D610 laptop goes black.
motherboard and graphics adapter may need replacement
Dec 22, 2009 | Dell Latitude D600 Notebook
I have Dell 2000sp monitor that was working fine. The none of my internet pages would load. I thought it was my connection and restarted the computer, but now the monitor is on, but the screen is black....
The only problem if it is the monitor that it could have is the connection. Check see if you cable is kinked coming out of the computer, and is conected properly. Usually everything else would be a problem with the computer.
You can also try hitting the buttons on the monitor to see if stuck.
Nov 05, 2009 | Dell 2000FP 20.1" LCD Monitor
Black screen
You have bad El-condensator on secondary side of power supply.
Oct 06, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
My monitor screen goes black
The monitor is going bad. Either going to be a bad screen or a bad inverter. Also Since you tried it on another computer and its still giving you the same symptoms, you know the computers are fine. To be sure, try another monitor on your computer and if you get video on the new monitor then thats another way of verifying that the dell monitor is bad.
May 16, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Power cable
Here is one in an ebay store
and here is a google shopping search with several options.
Aug 11, 2008 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Flickers and Lines
you have the vertical circuit "closed" you have to repair it checking
transistors and capacitors . if you can  it this work may be at low cost - few dollars
Mar 21, 2008 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Dell monitor dead
If all your lights are on on the front on the 2000FP then the logic board is bad and the eeprom at49bv8192at will need to be replaced and reprogrammed. Check out www.lcdrepair.us for Instruction videos on the 2000fp as well as parts
http://www.lcdrepair.us/Installation.html
Nov 29, 2007 | Dell 2000FP 20.1" LCD Monitor
Dell UltraSharp 2000FP 20.1" Flat Panel LCD Monitor Logo
2,493 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
