Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printing blank My printer is printing blank pages. I called Kodax they had me update the Firmware and it still did not print. I just received a new Printhead but it STILL wont print!! Help
  • rstech Sep 17, 2008
    I too have a problem with the black printer not printing. I did print out a demo page directly from the printer (Computer was not hooked up) and the black did not print, which is also the problem when I go to print text from the computer. I reset the printer to factory settings and still the same. I have also reloaded the software.
    I will be calling Kodak to see waht the problem here is. Stay posted and I will let you know waht I come up with. Any other suggestions?
The first thing you need to do is disconnect the printer from your computer, and try to print a demo sheet directly from the printer's control panel, then try to make a copy if the copy comes out right, that means you have a problem with your software or computer, so you should call them again and tell them the problem is still there, but only when you print from your computer.
Posted on Sep 13, 2008
Lexmark printer not dispensing ink
First, make sure you are using genuine Lexmark cartridges.
Second, try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
If the firmware update doesn't help, please perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If it still doesn't help, please contact our technical support team.
Jan 08, 2013 | Lexmark Impact S305 - multifunction ...
Will not receive faxes/sends faxes but no print on the page
A firmware update for your models addresses the issue where the printer is having trouble printing out any colors. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
After successfully updating your printer, run the Deep Clean Printhead function on your printer. From the printer operator panel, press the Setup button > Maintenance > Deep Clean Printhead.
Then try printing a document again to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Feb 15, 2012 | Lexmark Office Equipment & Supplies
Please give me any solution to stop 49 FF05 printer error
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on again.
3. Go to http:www.hp.com/
support/lj2420.
Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update, download the newer firmware upgrade. Not all printer models can receive firmware upgrades.
4. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
Aug 30, 2011 | HP LaserJet 2420 Printer
Kodax Eps-5 Printer want print with one cartridge
No you need functioning colour cart for black to work.
Apr 28, 2009 | Kodak ESP 5 Printer
I get blank pages when printing. Sometimes all pages are blank, sometimes first and last page print, with blank middle pages.
hi,check your printing setting and then print.
or....
uninstall the printer then install the printer again then printer has default setting and print the paper.
sometimes printer current pages print wich is selected by setting.you must select all the pages.
to change the setting,,,
1-open control panel then open printers and faxes then check seeting.
Apr 12, 2009 | HP DeskJet 842c InkJet Printer
Printing in page mode feeds extra blanc labels
Make sure,
you firmware is right one for that printer because in most of cases it happens due to wrong firmware and bad ADF kits. so check your ADF kids and if you find them fine the install updated firmware on in.
once you done with these all then turn your printer off and turn it back on.
post back if any thing changes and rate all answers.
Good luck
Feb 24, 2009 | Epson TM-L90
My Dell 962 printer only prints blank pages.
The ink is dry.
Try repeatly going through a cleaning cycle.
If not, remove all ink cartridges and pour some 100% Alcohol where the cartridge is and leave it there for 1 hour.
Afterwards, go through a few more cleaning cycle.
Make sure you have spare ink.
Jul 07, 2008 | Dell 962 Photo All-In-One InkJet Printer
Adjusting printheads - won't stop and keeps printing blank pages
Hi Did you have any print jobs sent to the printer before replacing the printhead. It seems that the printer is trying to print a job and since the usb cable has been disconnected and reconnected the printer is printing blank pages or misc text.
Dec 03, 2007 | HP Officejet 9110 All-In-One InkJet...
Linksys print server Model EPSX3
Firmware upgrade for your print server could fix your problem or kill your print server.
Try this first: SET UP A STANDARD TCP/IP port.
Set a static ip on the print server. Use that ip address to set up your STANDARD TCP/IP PORT. You can do this on the printers and faxes page.
Right click the default printer then click properties. You have to ADD A NEW PORT.
Good Day
Nov 05, 2007 | Linksys EtherFast 10/100 (epsx3/uk) Print...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
64 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
