Question about Epson Stylus 777 InkJet Printer
Epson 777 printer repair
I disassemled the printer to fix a roller that had broken off. After reasssembly the carriage moves all the way to its left jamming into something. Is there a process for re-aligning the carriage. Ps. All the tips on the epson website did not work. Thanks, gerry
  • 1 more comment
  • gerard lawrence May 11, 2006
    I did not have the carriage guide mounted correctly. The limit switch seems to be working OK. I will post another question thank you very much, Gerry
  • gerard lawrence May 15, 2006
    And so the saga continues. I found a service manual on esi.com. From what I read I now need an adjustment program to adjust the" bi-d". No one has heard of this program for the 777. Can I adjust without the adjustment program? If not
  • gerard lawrence May 16, 2006
    I may have found the adjustment program.It is contained in the service program I downloaded.It is compatible with windows 98 only.I am operating windows XP. Will this pose a problem. Thanks again boys.
    Gerry RRT.
  • 1,218 Answers
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Posted on Oct 04, 2010
    President:
  • 3,130 Answers
There is a limit switch on each side or some models its located by the cam. If you took apart the can assy then the units out of mechanical timing and you are gonna need a service manual for this. If the switch is not working on the side I myself forgot to plug back in the small plug on the curcuit board. Good Luck
Posted on May 10, 2006
SOURCE:
Head strucked in the left side of the printer
Printers are made of plastics, even those expensive looking and probably some piece has weared off. My experience is that this kind of failure can't be repaired by a user vithouth the repair kit and the technical knoledge. If you don't know how - most probably - you should take your printer to an authorized Epson repair site.
Apr 17, 2015 | Epson Dot Matrix LQ-300+II Printer
HP Photosmart C3180 carriage permanently stuck on right. How to fix this?
If the carriage totally stuck on the right side of the printer, Unplug the printer from Power outlet.
Open the front access door. You will see the cartridges. Remove the cartridges. Check for any paper stuck in the Carriage Rod. Try to manually move the carriage 5-6 times left to right and it should move without any trouble. Put the cartridges back into the Cartridge slot and power on the printer
If the Carriage does not move manually, there could be chances the printer needs mechanical repair as its broken.
Regards,
Sean
Sep 16, 2012 | HP Photosmart C3180 All-In-One InkJet...
My Epson CX8400 is flashing and error message that says turn off printer, turn on and see your documentation.... Far as I can see there is no paper jam and the only thing outta the ordinary is the inkset...
Whne turn on, printer move to left and right for checking carriage track, and measure it. If "something" block carriage moving, printer error occured. Check left side of carriage track. Did you use CISS?
Apr 11, 2010 | Epson Stylus Multifunction Inkjet Printer/...
No ink output from Epson Stylus Color 777
I don't have an answer for you but I have the exact same problem.
I have an Epson Stylus Color 777 and I put in new cartridges (black and color) that I bought yesterday (03/05/10).
I pulled the tape off the cartridges and inserted them in their carriages. Everything works like usual except that no ink at all prints on the page. Comes out completely blank.
Nov 11, 2009 | Epson Stylus Color 777 InkJet Printer
Epson CX2900 problem
HI,
Try to reset it :
SSC Utility has the latest version SSC Utility 4.30... This time it can now reset the Epson Stylus CX2900...
Download the latest version and Install it...
Under Configuration...
Select Installed Printer (EPSON Stylus CX2900 Series)
Under Printer Model
Select EPSON Stylus CX2800...
I hope this will help you. Link
Aug 02, 2008 | Epson Stylus C84 InkJet Printer
Epson stylus 777 printer
isent this the same printer that you asked about with a problem with the carrage not working correctly after disassembly to rerplace a roller?? If it is then you ptobably have a sensor misalighned or unit still is not "timed" correctly.
May 11, 2006 | Epson Stylus 777 InkJet Printer
Epson Stylus 777 InkJet Printer Logo
146 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
