Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
Frother doesn't froth
I've got a brand new machine but the frother doesn't seem to put out enough steam to properly froth the milk, and seems to drip water continuously. is this normal. I was hoping enough steam would come out to swirl the milk around the frothing jug.
    New Friend:
  • 39 Answers
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Posted on Dec 31, 2009
Frother only blows steam not frothed milk
The frother is only supposed to blow steam! At least on any of the dozens of machine I have used commercially. You put the frother into your cup of milky coffee and it blow steam and air through the coffee and makes froth. Go to Starbucks, stand near the side counter and watch.
Edited to add yours in not a normal machine, it is a home replica of a pro machine. I suspect it needs cleaning. You can get milk cleaning tablets and liquid for machine that has an enzyme to remove dried or burnt on milk solids.
Here is your manual.
Mar 07, 2017 | Coffee Makers & Espresso Machines
Hi, the steam from the wand is not frothing the milk like it used to, hardly any froth at all.
If the frother is warming the milk, but is not frothing, then you want to make sure the panarello is clean.
Slide the cover off the frother and check the pin hold on the top edge of the cover. If this hole is blocked the milk will not froth. Rinza is great clean to help prevent these issues.
Also recommend frothing water instead of milk to clean the frother well.
For more information visit:
Jun 07, 2011 | Gaggia Brera Coffee Maker
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Low pressure on milk frother on breville coffee machine
First,I'm NOT a Breville tech, but this is a very common problem with steam boilers. Your valve seal(s) are worn and needs replacement. Any leaking water or steaming from various places other than the steam tip is causing your tank to lose pressure. The heater needs to stay on longer just to keep everything up to pressure and properly heated. You probably noticed that your shots may not have the creme or very thin and watery. Milk steaming takes a long time or not enough steam to complete a froth, especially on a Latte. Your machine needs servicing. Contact your vendor or MFR for service.
** loose steam wands will fall off and be re-assembled without the ball seal or washer. Look around the machine for a round disk made of hard rubber or nylon plastic. Take apart the wand and reassemble with the washer or get a new washer and tighten,.
** other places were you can loose steam pressure is the Anti-siphon valve, Safety valve, and various pipe fittings to the steam boiler. Look for steaming plumes from unexpected areas of the machine.
** Scale that has built up to the point of causing valve problems are usually too much for DE-scaling to work properly. Usually done as a preventive maintenance rather an alternate to repair. Like a blood clot, if you remove it while still in an active system. Where does this clog end up? This debris needs to be physically removed from the pipes, valves, and/or tank. Heavy scaling is a sign of an old machine that will need a lot of servicing to bring it up to MFR specifications.
** Final; The steam wand(s) are the most used (and abused) parts of the machine. Constant cleaning is a required task that needs very diligent baristas to keep it fully functional. I've found that best operators use the following method to keep the steam wand in top condition; Remove milk froth pitcher completely from wand, Send a short blast of steam to clear milk residue from tip. Take a damp towel to grab wand an pull downward to wipe off any remaining milk residue. Leave the wand in a pitcher of cool water to soak during long break periods to help break up any dried milk. Let soak over nite when not in use. Have your operators notify you of any 'loosey-goosey" wands. Tighten them properly but make sure all the parts and washers are there. Check your manual or just ask your technician to show you the next time.
*Have a safe New year! Aloha! ukeboy57
Dec 24, 2017 | Breville Coffee Makers & Espresso Machines
Seaco Incanto not frothing milk properly
When was the last time you descaled the machine, and not with vinegar? Scale can accumulate inside the boilers and insulate the water from the heating elements, produce less steam. Descale on a regular basis.
May 12, 2009 | Saeco Magic De Luxe Espresso Machine
The frothing stick doesn't seem to work
descaling time not with vinegar with descaler vinegar remove calcium in little piece descaler melt it use 1 part descaler 1 part water put in the water container start it up open valve after a few second turn it off leave it for15 minute repeat untill empty after do 2or3 rince descaler is corosif thank you for using fixya pierre
Feb 10, 2008 | Dualit Espresso 889 Espresso & Coffee...
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
798 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
