Question about Lexmark Office Equipment & Supplies
I have here a Lexmark X73 copying machine,fax,scan,e-mail and I am tring to get it connected to my tower which is HP pavillion could you help me with this hook up
    Genius:
  • 1,689 Answers
Jfergie, did your computer give you an error message or you are in the initial method on getting this one working on your computer?
Posted on Sep 12, 2008
Lexmark X73 Printing Problem
When you say that your all-in-one system will copy, but will not print from the computer, this tells me that there could be a connection problem between the printer and the computer. This is more then likely a driver problem. you will need to go to lexmark and download the latest drivers for your operating system.
But this could also be a broken or loose cable.
Apr 15, 2010 | Lexmark X73 All-In-One InkJet Printer
Just purchased a hp pavilion and tried to install my lexmark x73 and it wasn't compatible. Any solutions to this problem.
http://www.hpdownloadsdriver.com/updates.php?t=Lexmark%20X73%20All%20In%20One
Install the driver/s from this link/site and then install your Lexmark X73. This is for windows/HP/Lexmark....I do believe it will be compatible.
Good luck.
Aug 29, 2009 | Lexmark X73 All-In-One InkJet Printer
I have a lexmark x73 i'been instaling so manytimes on order to make the scaner to work but nothing I would apreciatte if you can give me some tips or help thanks
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Lexmark X73) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | Lexmark X73 All-In-One InkJet Printer
Faxing
WEll the x7350 is a fax and scanner and copier plus printer. Which x73 do you have?
Jul 27, 2008 | Lexmark X73 All-In-One InkJet Printer
Trouble scanning without pc
Using the operator panel:
  1. Turn the printer on.
  2. Open the top cover.
  3. Place the document face down in the lower right corner.
  4. Close the top cover.
  5. Press the Color or the Black copy button as required.
Using the computer:
  1. Make sure the printer and your computer are turned on.
  3. Place the document face down on the scanner bed in the lower right corner.
  5. Click Start, Programs, Lexmark Xx3, Scan & Copy Control Program.
  6. Select the number of copies.
  7. Click the option that matches the desired color of the copy.
  8. Click the Copy button.
To customize the copy settings:
  1. Click Start, Settings, Lexmark Xx3, Scan & Copy Control Program.
  2. Click File and then Setup.
  3. Select the Copy/Fax tab.
  4. Customize your settings as required.
  5. Select OK to start copying
Apr 04, 2008 | Lexmark X73 All-In-One InkJet Printer
The included X73 OCR has disappeared
When you install software install in another location ( do not install in program files as normally ) let me know if u got help!
Mar 24, 2008 | Lexmark X73 All-In-One InkJet Printer
Scanner will not scan
Set this options un der Control panel Scanner and camera. If fails try this, Uninstall everything HP Installed. Unplug the scanner. Then reboot. THen install the drivers and applications. Then reboot. then insert the HP scanner into the USB.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73
Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. 2. You hire an Internet E-faxing service. See · http://www.slipstick.com/addins/services/fax.htm#internetfax · http://www.slipstick.com/addins/services/fax.htm · http://www.savetz.com/fax Tim
Jan 30, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
