Question about Fujitsu 18C1 Air Conditioner
Aou18c1 not shutting off
Hi I've got a fujitsu split type its running good but it won't shut off even the room temperature is satisfied already. Do I neede to replace the remote controller?
No, I mean the compressor wont stop , Relay is O.K
Posted on Sep 27, 2008
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Posted on Sep 26, 2008
Does this model shut off automatically when the desired room temperature is reached or does it function on a low medium high type of thermostat that continuously runs? IR 3 0 p m d g - 1
if it is an inverter type air conditioner ( make not indicated) the unit runs continually but the compressor delivery is reduced thereby reducing the load on the motor
as the room warms up again the compressor starts to pump more gas to keep the room at the desired temp setting
older types shut the compressor down and restarted when the high temp was reached
Jan 19, 2018 | Heating & Cooling
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
Ductless split LG LS240CP keeps shutting off with reaching room temperature
Does it start back up when the temp rises? What mode are you running in? Auto or cool?
Sep 25, 2013 | Heating & Cooling
Hello. I'm having a little problem... I have an White-Westinghouse split-type air conditioner (model WSA12PTGMA). The problem is i've lost the user guide manual... and now (after a long period of...
The unit is low on refrigerant and the freeze sensor is shutting the unit down... if you reset it is will wait for the 15-20min to time out before it shuts down again...
heatman101
Jun 20, 2011 | Electrolux Heating & Cooling
Thermostat is not shutting off heater..... can't adjust....gets room too hot. I keep on pilot only this is a EMpire RH25
Your heater uses a capillary bulb type thermostat sensor. If the small copper tubing that runs from the copper bulb to the control valve ls bent or crimped, it won't work properly or at all. Try setting the temperature at the lowest level, so that the room heats up gradually. Then, see if the Thermostat shuts it off. Also check the air intake on the front of the heater to make sure it's not obstructed or clogged in any way. If all else fails, contact Empire Comfort Systems Technical Service Dept @ 800-851-9396.
Hope this helps you troubleshoot and solve the problem.
May 02, 2011 | Empire RH35 Mid-Size Heater
Projector heating up and bulb shuts down
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 08, 2010 | Dell 2300MP Multimedia Projector
My compressor never shut off it works contiuisly . i have a split unit it's new
CHECK THE TEMPERATURE OF THE AIR COMMING OUT SHOULD BE AROUND 45 DEG TO 55 DEG IF NOT THE UNIT MAY BE LOW ON CHARGE AND NOT BEING SATISFIED TO TEMP.AND WON'T SHUT OFF
Oct 22, 2009 | Kenmore 75088 Air Conditioner
Appliaance shuts off at low temperatures
Most refrigerators cycle on and off based on the fresh foods temp. If the ambient temp is 10C and you have it set for 4C, the unit does not have to run much to satisfy the temperature control, and the temp in the freezer section will warm to + C range. (likewise, if the ambient drops to -C range, it won't mater if you set the fresh food section to +4C, it won't heat the air, and the fresh food section will eventually reach the -C ambient temp.) The only solution is to move the appliance to a warmer location or heat the room it is in. This is the only Fix-Ya for your refrigerator.
Jan 03, 2009 | Refrigerators
Fujitsu 18C1 Air Conditioner Logo
444 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
