Question about Ricoh Aficio 450 Copier
Ricoh Aficio 350e
I was called out to the machine because it had an error code, SC322. I was able to reset the code but after I did the machine would warm up I watched the heater lamp come on. Yet the display read please wait auto start. It would never code out and would never allow me to make a copy. I replace the harddrive, the Laser Diode Unit, the Power source board, the BICU board, and the IOB board and the problem persists. I'm stumped and was wondering if anyone has ran across this problem and do they have a solution to fix it. Any help appreciated. Thank you.
  • Ricoh Master
  • 2,794 Answers
I haven't seen that error code before. Definately something going on with the optics.
Theres a source for copier technicians only you might want to check out called copytechnet.com. There are Ricoh experts on there for such problems.
It's free to use.
Posted on Sep 12, 2008
Really this post helped me too much
http://www.fixya.com/support/t3469159-1035_ricoh_aficio_printer_error_code_322
Posted on Dec 17, 2009
My copier Ricoh Aficio 1515mf is writing call for service
You must specify the error, displayed in lcd, something like Sc322 or sc 548, etc..
That will tell the technician witch part to look,laser, fusion,optics etc. Penzance are right! Go on, post it!
Feb 13, 2015 | Ricoh Aficio 1515MF Digital Copier 15cpm....
How do i clear code sc322 on nashua aficio 2016
Code SC322: Laser synchronization error
The main scan synchronization detector board cannot detect the laser synchronization signal for more than 5 consecutive 100 ms intervals.
Causes:
• Poor connection between the LD unit and the BICU board
• Damaged cable between BICU and LD unit
• LD unit out of position
• LD unit defective
• BICU board defective
Error Codes Ricoh Aficio 2016
Jan 04, 2015 | Office Equipment & Supplies
Aficio 350e error code sc547_00
fuser unit error ,go to simulation i.e press 107 and press cancel key and hold then switch off machine an on
Aug 11, 2013 | Ricoh Aficio 450 Copier
Codigo sc-322-000 copier ricoh aficio 450
sc322 is an error generally caused by a component in the laser unit. However, sometimes a faulty door switch can cause this error as well. The switches in question are the three micro-switches that change state when the right door is opened or closed. They are located on the front right side of the copier, above the fusing unit and behind a plastic cover. If you can remove these switches and test them individually, you can probably find the faulty switch. If not, you can replace all three as a set and hopefully the sc322 error will go away (once you reset the machine).
If replacing the switches do not fix the error, then the problem lies somewhere in the laser unit, possibly with the polygon mirror motor, but your best bet is to replace the whole laser assembly if you can.
Hope that helps!
Oct 22, 2010 | Ricoh Aficio 450 Copier
After sc326-00 my copieur ricoh aficio 350 put on his screen sc322-00 and not work, how cold i resolve this problem
Laser Synchronization Error(1 & 2)(sc322 & sc326)
· Laser synchronization detector board out of position
· Laser synchronization detector board defective
Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
Feb 09, 2010 | Ricoh Aficio 350e Printer
I need the fuser reset code for the Ricoh Aficio 350
Try to reset with 5801 it means:
enter service mode with 107 and find 5801 and execute then switch on and off the copier.
Please try if it works.
Oct 15, 2009 | Ricoh Aficio 350e Printer
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 19, 2009 | Ricoh Aficio 180 Laser Printer
The problem is sc326 and sc322 in ricoh350
see my posts about the same problem here. It's a newer version of the machine you have, but the results are the same:
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Apr 08, 2009 | Ricoh Aficio 350e Printer
Ricoh AP2600 printer gives an error message of SC322
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Feb 10, 2009 | Ricoh Aficio AP2600 Laser Printer
Ricoh Aficio 450 Copier Logo
228 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
