Http://www.fujifilm.com/support/index.html
go to that link and you can locate the nearest service center.
Thanks,
Lee
Very delicate piece of equipment and dropping it will cause internal damage. dismantling it may help, do you have the proper equipment and the know-how ? else better have it checked.
The lens mechanism is jammed or broken, the camera needs to be taken apart and inspected. I would suggest agains it, as these things may break easyly or you might not get it back together.
I can recommend a few repair places:
Advance camera - you can get a free repair estimate from here
http://www.advancecamera.com/repair
and Precision Camera
http://www.precisioncamera.com/
Well there are a few things you can try at your own risk:
Tap the camera on the sides, keep turning it on and off, maybe it might unjam, of if broken it wont do any good.
Take the camera apart and inspect the lens mechanism, if parts are broken you need to replace them.
You can even try rotating the lens yourself, to the direction it rotates, this is a little risky and might make it worse so try at your own risk.
this may be helpful to you
http://www.fixya.com/support/t143152-fuj...
seems your unable to see my solution, well just dropping in a comment incase you could see it.
camera is stuck on zoom error and can't take pictures
yes
