Question about Amana RanARG7302 Gas Kitchen Range
AMANA GAS RANGE ARG7302 MODEL SERIAL # 9906300541 MFG: P1143343 NWW This Amana gas range as far as the top 4 burners-they all work. But the light on the top of the stove wall where the knob to turn on over to temperature or broiler does not work. And the oven and broiler do not come on All plugs are plugged in working outlet. Could this be the ignitor switch? or another problem. The burners click when coming on; but when turning knob on over to set 350 - it does not ignite at all-nothing. my phone 585 268-8009 email: bettyboopster43@yahoo.com Any help will be appreciated. Betty J Dombek Thank you
  • Anonymous Mar 16, 2014
    Amana gas cook top stove electronic ignition not working
  • 4 Answers
Sounds like the thermostat
Posted on Dec 11, 2008
Amana gas range top. Burners click but see no spark and won't light
Make sure the gas is on or connected or just call a repair man
Sep 19, 2015 | Amana Kitchen Ranges
Trouble with an Amana oven
sounds like a bad valve that needs to be replaced. If that doesn't fix it let me know but 90% of the time this is the problem and the fix.
good luck and let me know if you have any other questions with this
Jun 06, 2008 | Amana RanARG7302 Gas Kitchen Range
Manual
When the range top burners and the oven are both not lighting, I recommend you check if the manual shut-off valve to the range has been turned off. With most of my gas ranges, you have to remove the drawer to reach the shut-off valve. (so If you have propane, make sure that your tank isn't low.
Make sure that your home is well ventilated; open the windows and check the range in a while. I live in an area where we had to add a whole house ventilator. We had days where the house would seem stuffy and none of the burners would light. (Appliances with pilot lights went out.) This was due to excess carbon dioxide shifting from nearby coal and natural gas deposits.
It is possible for the igniters to fail if there is power to the range, but usually not the oven, the broiler and all of the top burners at once. You can test the top burners carefully with a long handled butane lighter or a long match. Turn on the hood fan and set a burner to the Lite position. Carefully, light the lighter near the burner or bring the lit match to the burner. If the gas is flowing properly and there is sufficient oxygen, it should light. Then remove the lighter or match and put it out. Then adjust the burner temperature.
The manual for the ARGS7650SS is available from Amana. The direct link is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/31810401.PDF . Many newer Amana product manuals are available here: http://shop.amana.com/product_literature/search.jsp .
I hope this helps.
(note: you should also make sure that the regulator cap is correctly set for your type of gas (LP or NG). The gas flow rates are different enough to make the regulator fail. Most ranges are shipped for with the cap set for NG. Turn off the gas and unplug the electrical cord before working on the regulator cap. The burner orifices need to be changed as well as some other adjustments to convert from NG to LP. See pages 9-11 of the manual for details.)
Jun 26, 2013 | Amana ARGS7650SS Gas Kitchen Range
Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Oct 03, 2009 | Amana AGDS902 Gas Kitchen Range
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
check the door switch
check the termocouple
hamid
hhamidi56@hotmail.com
Jul 26, 2008 | Amana RanARG7302 Gas Kitchen Range
Gas Range Oven use without electrical power
It will be necessary to change the top burner orifices when converting to propane. You should be able to light the top burners with a match or lighter, however, the oven will need proper operating voltage.
May 22, 2008 | Amana Ovens
Amana Range ARG7300W
yep open the oven door unplug the range remove the racks on the bottom liner should be some screws remove them then take the liner up and out if there is a flame spreadder on the burner tube remove it at the back of the burner bar should be the ignighter most new ones are generic you just cut the wires on the old one and splice the new one on with cerramic wire nuts make sure the wires are away from the burner bar reverse dissambily turn oven on should light within 30 secs if ya pluggedit back in
Dec 29, 2007 | Amana RanARG7302 Gas Kitchen Range
Amana RanARG7302 Gas Kitchen Range Logo
525 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
