Question about Dell HK395 Computer Speakers
No audio sounds from philips speakers
Please help me, how can i get my audio devices to work?
  • gerikiss4u Sep 12, 2008
    My speakers are not working and I do not have the original disc for installations.
  • 4 Answers
BVX
Posted on Sep 15, 2008
First of all can you test your speakers by plugging maybe an Ipod or similar into them using the green connector of the speakers to the head phone socket of the ipod which will identify if it is the speakers or the computer at fault and we will go from there :-)
Jonathan
Posted on Sep 13, 2008
My speakers are not working. I'm on an HP and have Philips speakers. They have worked fine before, but we recently moved and since the move they have not worked. Help?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 23, 2011 | HP Audio Players & Recorders
My speakers phillips ambx premium kit was recently bought and all was well, with everything working fine but a few days ago the lights have stopped working due to not being registered on the ambx...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Jun 11, 2011 | Philips SGC5103BD 2.1 Speakers
Using Philips SPA5200 speakers on a compaq laptop running vista. Control panel device manager says that the driver software is installed but device will not start code10. Control panel sound says no audio...
also
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 06, 2011 | Philips SPA5200 2 Speakers
My philips dss330 speakers is not functioning i dont whats the problem can someone help me to fixed it.....thanks
also
hope this helps
Mar 21, 2011 | Philips DSS 330 Computer Speakers
Computer will not recognize Philips Portable Speaker System SBP1150.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 28, 2010 | Philips SBP1100/37 Portable Speaker System...
I have reconnected my Philips MMS 321 speakers to my computer and my computer does not even acknoledge they are connected. My I put my Magicjack on this computer, it tookover as my default audio source....
go to "Start/Control Panel/Sounds and Audio Devices/Audio" and correct set the "Sound Playback Default Device" and "Sound Recording Default Device" settings to be your computer speakers (i.e. computer sound card device).
Aug 27, 2010 | Philips MMS 321 Computer Speakers
I just re-assemble my computer and speakers and my speakers is not working now. I am not sure if I have left a plug out. Should something be plugged into the 'Audio In" slot?
Audio in is an auxillary imput. Your speakers should be plugged into audio out. Check the power supply to your speakers. Enter Control Panel > System> and Device manager and make sure your audio drivers are working. Also enter Control Panel > Sound and Audio Devices and check the box that says "Place volume icon in the taskbar then open the volume control and make sure none of them are muted and that your volume levels are high. You can then click on the sounds tab and choose one of the sounds and hit the test button to check your speakers. Hope this helps. If all else fails check your speakers on someone else's computer.
Nov 19, 2009 | Philips MMS171 Computer Speakers
Speakers not working.
The easy way to trouble shoot sound problems is to plug the speakers into another device like a portable player and see if they produce sound. If you had sound from your portable device but no sound from your speakers then your speakers have died. You can see if the computer is producing any sound by pluging your headphones from the portable into the computer and see if you have sound.
May 01, 2009 | Audio Players & Recorders
Have stopped getting voice audio.
Reinstall the Audio Device driver .
Mar 31, 2009 | Audio Players & Recorders
Speaker not working
Check the plug going to your computer. Check to make sure the speakers are plugged up and turned on.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Jun 03, 2008 | Audio Players & Recorders
Dell HK395 Computer Speakers Logo
64 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
SmartAviator
SmartAviator
masterwest
Level 1 Expert
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
