Check that you don't have MIDI echo on in the DAW. If the MIDI data is echoed, it MAY be merging with the outgoing and when MIDI signals are merged in pieces instead of whole messages the data is corrupted. If you can look at the data stream with software, you should be able to spot the problem. Another problem might be excessive latency of the recording software. Make sure you do not have antivirus or antispyware programs running or network running. The Roland will spill data at much less rate and while the dd55 may overrun the DAW the Roland might not be able to. The key to the problem is to analyze the MIDI data stream that is being recorded.
additional info- when I plug my dd-55 into my roland gr-30 it doesn't seem to produce any rogue notes, so I guess it must be the emu x-2x2 creating the distortion
