Question about Garden
Ariens Yard Tractor 935 Series - initially drives, then stops moving as it gets warm
I was gifted this yard tractor recently. The owner said that it ran, and it does - it easily starts, the the mower blades spin, the engine sounds fine and it even moves forward and backward for a little while. But then, after 15 min. of mowing or less, going forward or backward becomes progressivley more difficult until the tractor doesn't move at all. After awhile sitting, the tractorwill move forward again. Any ideas on what this is? And what the fix is?
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    is it belt or hydraulic driven?
  • 49 Answers
Is it a hydrostatic tranmission? If so, sounds like the fluid might be old or not the right viscosity. Recommend changing the trans fluid, and use recommended viscosity of fluid.
Posted on Feb 06, 2009
  • Al Perry Feb 06, 2009
Ariens 935 Yard Tractor. Battery fully charged. Why won't it start unless jumped?
Is the battery actually fully charged? A dead cell will kill any power. Try another battery.
May 14, 2015 | Garden
My craftsman yard tractor all of a sudden will not move, 42 " cut , 15.5.hp kohler motor Hydrostatic drive ,!
bypass rod pulled out to allow pushing the tractor, the noise is the hydrostat bypassing fluid (normal) if my crystal works
Apr 01, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
My Yard Machine tractor stopped moving in any direction. When the clutch is pressed in it feels sloppy and will not engage the gears when it is let up? What is the problem?
Check the main drive belt. It is either broken or out of place. It is the one driven by the upper pulley under the engine and drives a pulley on the transaxle.
Jul 22, 2011 | Yard Machines Garden
I have a ariens yard tractor YT 150 H model number 936012 serial number 004697 . I have replaced the pto switch and the relay and every time I engage the blades the mower cuts off. Could you please tell...
I have the same model and had the same problem. Ended up being a bad bearing in one of the deck pulleys. You can find it by disconnecting the drive belt for the blades and turning the pulley by hand. One of them is going to be a lot tighter than the other. You should probably replace both while you have it torn apart...
Oct 22, 2010 | Garden
if it does not turn over with the key check the battery check the 25 or 20 amp fuse
Sep 24, 2009 | Garden
Runs greeat but moves forward very slowly
Is this a gear drive or hydro ? If its hydro may need oil change and filter(tranmission) If not its most likely the belt.
Apr 11, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
695 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
