TL-WR340G Wireless Router
Help.... I have a TL-WR340G Wireless Router running on XP, I have set up the router and is connecting with usb adapter, I have followed the Quick Setup as instructed IP is 192.168.1 254, Subnet Mask is 255.255.255.0 , Gateway is 192.168.1.1 and user name admin Password admin,Yet I am unable to connect to the internet, is there something I have missed out ?? This is my first time trying to use a router so I am a bit of a novis....all help appreciated
  • 2 more comments
  • Anonymous Nov 06, 2008
    I have the same problem as above. I have followed all the instructions in the Quick installation setup, but it cannot connect to the internet. I'm using virgin media broadband.
  • xandars Dec 31, 2008
    same problem.. all passed well, Local area network works perfectly, but i cannot go to internet. when i turn off the device, i go regularly on internet via router.
  • hackz08 Apr 13, 2009
    lately, my router is working after 1 month i cant connect to the internet but internet only, when i try to used network or sharing files its ok i have no problem encounter..i directly connected the modem to pc and boom i have internet connection...maybe the problem is router because when im plug it the modem to the router no response from my wireless broadband..the configuration of router is ok factory defaults, im trying also to reset the router but same problem pls help me if what im doing to my router...TP link wr340g
  • labski May 19, 2009
    i have the same problem as above. I have followed all the instructions in the installation guide, but i cannot connect to the internet. i'm using TL-WR340G.
Best solution, copy the MAC address or Physical of your PC and clone it into your TL-WR340G (in short, change the MAC address of your TL-WR340G)
Posted on Jul 04, 2009
  • 400 Answers
You all can try contacting your you ISP while they will provide you with some configuration and than it would work smooth as on direct conneted to modem .... its mainly the problem from Static ip , dynamic ip and pppoe mainly the connection we get is of PPPOE... and you can try puting PPPOE up to then Dynamic Ip
Posted on May 31, 2009
HOW TO SET UP TL-MR3420 USING GLOBE POSTPAID CONNECTION
follow these steps:
1- connect your pc with router
2- open browser.
3- type the ip address of router : 192.168.0.1
4- press on quick setup.
5- choose the first option 3g/4g
6- press next
7-set location , AT&A , username , password
8- press next
9- finish
make sure your wireless usb was connected with router in the area range of wireless of your isp .
Nov 27, 2013 | TP-LINK TL-MR3420 Wireless Router
How to configure TP-link TL-wr340g on tata broadband
If you don't have any internet access, you can reset the router by unplugging it from power and then plug it back in. Do the same for your ADSL or cable ISP modem which you have connected on your TP-Link router.
RESET FIRST YOUR ADSL MODEM and then your router.
Other solution might be to do ipconfig /release and ipconfig /renew on your command line window from your computer.
You can find your wifi router's user manual (PDF) on this link:
http://www.tp-link.com/resources/software/200943083466.pdf
Please mark as solution if this helped you at all.
Thanks.
Jan 29, 2012 | TP-LINK Computers & Internet
How to connect TP Link G Wireless TL-WR340G Router? My neighbor wants to connect an internet with us and I don't know how to install a router.
I have found you a manual to help you with the setup.
Basically, you login to the router via a browser, put in password and network information, then save the configuration. http://office.manualsonline.com/manuals/mfg/dlink_systems/di514_1.html
Mar 05, 2010 | D-Link DI 514 Wireless Router (DI-514)
Tip link wireless router WR340G will not conect
how i can change the pasward of this router(TL-WR740N)? and i has forget my pasword and user name.
Feb 01, 2010 | NetGear RP614 Router
Cannot connct xbox 360 wireless adaptor
Your XBOX 360 adapter should automatically be assigned an address by the router's DHCP server. I think you may be having a problem with your wireless configuration. Check the wireless settings on your router to confirm that it is indeed setup for WEP. If it is setup for WEP on bothe the router and the XBOX and the key is typed in correctly on the XBOX it should work. If it still doesn't however, disable the wireless security on your router, then restart your XBOX and see if it will connect without WEP. Many devices will have problems over WEP and not connect at all. If it connects fine with no security enabled then we will know that was the problem and I would sugest changing the security to WPA.
Jan 05, 2009 | Microsoft Wireless Network Adapter Xbox...
TP-LINK TL-WR340G, No internet connection
Look for the MAC address clone feature on the router. If the router does not ahve the auto clone MAC feature, you'll need to manually input the MAC address of your computer.
To get the MAC address or Physical address of the computer do this
Click start>run>type in "cmd" and press okay (without the " ").
On the Command prompt type in ipconfig/all and then press enter, look for physical address.
Then input that on the MAC clone feature of the computer to your router and then power cycle everything (turn everything off and then turn on modem first-then router-then computer).
Sep 12, 2008 | Trendware TEW-630APB (TEW630APB)
TP-LINK 54M Wireless Router
pls ckeck your connectivity status
use this command to test for connectivity from your isp 'ping <ip address>
Apr 23, 2008 | Computers & Internet
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Computers & Internet Logo
5,620 people viewed this question
David Payne
David Payne
