Question about HP Photosmart M305v Digital Camera
LCD screen- white with multiple colored diagonal lines
Hello, I used my digital camera just two weeks ago and it worked just fine. I have never had a problem with it? then just the other day at my daughters birthday party, I turned on the camera and the LCD display appears white with Black, Green, and Pink lines running in all dirctions. It kind of looks like a smashed windsheild. I have no idea how this could be something that I have done since I always put it back in it's case after use and I store it in a hall closet at home when I'm not using it. It's never been left in the car and exposed to excessive heat or cold. I didn't drop it either. I hope you have a solution that doens't cost as much as buying a new one? but since the camera only cost me $125, I get the feeling that's going to be my only recourse. It kind of sucks to just have the camera a little over a year and for it to just stop working convienently after the warranty is over. Anyway, I'd just like to know what in the world is wrong with it and how it may have got this way. Any ideas from you would be much appreciated. Thanks.
  • 21 Answers
Re: LCD screen- white with multiple colored diagonal...
Hi: Because the camera it's an HP and I don't know the camera so well I sugest to visit the HP site and search for your camera. After go to the FAQ and you have one options that allows you to chat with a HP Technician. I think it's the fastest way Regards
Posted on May 10, 2006
0 characters
3 Points
I bought a Sony Cyber-Shot DSC-W530 camera 4 weeks ago. About 2 weeks ago the screen developed a bright white spot along the one corner- the display would not show in that area. I didn't do anything...
If you turn off the LCD screen and use the viewfinder, same problem? Even with this wrong, are you try to take pics and see this in your pc? They are white or with some lines over image?
Two things there, first... could be a problem with the viewer screen, or, second choice could a problem CCD sensor go to bad; in both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Olympus service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Keep in mind and check if even you are underwarranty, if yes, applied.
Hope this helps.
Jul 21, 2011 | Sony Cyber-Shot DSC-W530 Digital Camera
White LCD screen
The LCD connection may be loose or the LCD itself broken. You may need to have a service centre replace the LCD unit.
Apr 13, 2009 | Canon PowerShot SX10 IS Digital Camera
Screen does not work
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
Apr 10, 2009 | Kodak Easyshare M893 Digital Camera
Kodak C633....
No It can be replaced for under 100.00 and you keep your camera. It is a pretty easy fix.
Jan 01, 2008 | Kodak EasyShare C633 Digital Camera
Purple lcd display
Hello tonyj111, If your old pictures look fine on the display, then the problem is related to the ccd sensor itself. The purple color is displayed because of a problem in the signal transmision from the ccd sensor to the camera's main processor. This is done using 3 channels one for each primary color (RGB red green blue). If the connector to the sensor is broken, or got out of place (loose) because some mechanic shock or symilar, the data processing woun't come out right. It is purple because your camera's processor mess up blue and red signals therefore resulting same purple instead of blue or red colours. In order to fix this you will need to either send the camera to a service center to have those connections checked (if your camera is still in warranty you will want to do this) or ask me for further instructions if you wish to try to dissasemble the camera yourself. In either way the problem is fixable and in most probabilities a cheap fix will work. Good luck
Jun 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
My LCD screen shows a colorful vertical line & then the screen goes white
Hello, The problem is in bad contacts on flat cable from the LCD. Cleaning the cable and the connector can solve the problem. If you need more info please advice. ps: this should be the long term solution.
Apr 21, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Fuji f700
I recently had trouble with the LCD Display coming up with a black screen. So I mailed it to Fuji with a letter explaining the problem. About 3 weeks later I got it back in the mail and it seem to be working fine until a month later. I turned it on and the LCD display show a black screen only now it has white lines. I'm so incredible mad and extremely dissapointed in Fuji. Reading online I have notice many people having trouble with Fuji Products. I WILL NEVER BUY a Fuji again!!!
Jan 15, 2007 | Fuji FinePix F700 Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
Finepix A310
Dose the video out look the same as if it does then you have a faulty ccd processor or lcd itself is bad. It may be time for a new camera.
May 04, 2006 | Fuji FinePix A310 Digital Camera
HP Photosmart M305v Digital Camera Logo
62 people viewed this question
Top HP Digital Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Digital Camera Expert? Answer questions, earn points and help others
