Question about Maytag Dishwashers
Maytag dishwasher The dishwasher goes through the first wash cycle on a light setting and first two on a normal cycle but will not continue.The motor hums but does nothing else.It drains fine as well after the wash cycle.
    An expert whose answer gotĀ voted for 100 times.
  • 171 Answers
Hi kimleh.
I'm Harvey the Master Plumber.
Your question is: The dishwasher goes through the first wash cycle on a light setting and first two on a normal cycle but will not continue.The motor hums but does nothing else.It drains fine as well after the wash cycle.
Without additional info it sounds like a control problem. Must be a warranty call. If beyond warranty then you have to decide whether it's more cost effective to repare or replace it.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 12, 2008
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
May 30, 2012 | Maytag Washing Machines
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
I have a maytag dishwasher and the light wash light stays on even after a wash cycle. Tried to press normal wash and goes back to light wash. What could be wrong?
Buttons could be shorting out and not makeing proper contact from just being old,How old is you unit?? Alway put age with your question,,on anything! Nobody wants to beleive there unit is old,Humane nature I guess, Always keep manual with purchase date in it handy.If it lasted more than 5 years your very lucky.specially if you use it everyday.
May 15, 2010 | Maytag 24 in. MDBH950AWS Built-in...
When i push the normal wash button and it changes to another cycle after a few minutes then wont run at all just freezes up some water was in the basin modelmdb9100
What you're describing as changing to another cycle may be the dishwasher trying to display diagnostic information. For example, if you ran a Normal cycle and it appears to switch to Light Wash, check to see if the "Clean" indicator is also lit. This would indicate a motor fault, which would explain why it appears to "freeze".
May 12, 2010 | Maytag MDB9100A Dishwasher
Maytag mjd 2005 when started on normal gives a once-every-two-seconds "wash". Seems to pump out some water each time. When turned off and on again 'normal' button lights and the same thing happens. Will...
I have the same problem but now on all cycles - to get it off normal and try the other ones, open the door, hold down the 'normal' button for three seconds, and then at least try the other settings temporarily.
Mar 30, 2010 | Maytag 24 in. MDB9750AW Dishwasher
My carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Mar 16, 2009 | Maytag 24 in. MDBH965AW Built-in...
Hi my hoover 6612 dishwasher does its pre-wash but then when the light for wash comes on it does nothing. I wondered if it might be a capacitor which needed replacing but I can't find one - any ideas??
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
Check start capacitor on the left side of the wash motor
Mar 13, 2009 | Dishwashers
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwashers Logo
162 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
