Question about Lexmark Wheelwriter 10 Series II Typewriter
Can't turn off re print
I am typing library index cards and only need one reprint. How do I get the reprint to not reprint everything that I previously typed.
  • koney Sep 16, 2008
    Yes thank you. I did find an old manual in storage and did see that pulling the paper bail load lever and typing a character after will clear the reprint mode.
  • Lexmark Master
  • 3,594 Answers
If you use the SAPI (semi automatic paper insertion) feature before you type the info you want to reprint the reprint memory will only have what you typed after SAPI.
You activate SAPI by pulling the rt. upper bail arm fully forward.
DickyO
Posted on Sep 15, 2008
NEED TO REPRINT RECEIVED FAX HP OFFICEJET 4500
Yes, You can.
Press Settings (The Wrench Button)
Navigate to "Print Report" - Press OK
Navigate to "Reprint Faxes" - Press OK
"Reprint All Faxes" - Press OK
Or Navigate to "Reprint One" - Press OK
Navigate to Date/Time Received of fax to reprint - Press OK
May 19, 2012 | Brother IntelliFax-2820 Laser Fax
Good Day! We have a IBM Wheelwriter 15, series II. How do you auto multi print? Example - mailing label. Unable to locate a manual. Please assist ASAP. Thank you very much! *Reen*
The WW15 only has a reprint feature not an addressable Type your info, put in another lable and press reprint you can do this until you type something else then it is changed You can get a manual
@ http://support.lexmark.com/index?page=content&id=SO4998&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT I suggest you copy amd paste this it's a long one.
DickyO
Mar 08, 2011 | Lexmark Wheelwriter 15 Series II...
Need to print a fax in memory, machine was turned off and unplugged
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory
option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How to type in a name and have it automatically type on forms
The WW1000 has a reprint key on the upper L. of the keyboard.
This key will reprint anything that has just been typed.
Turn the T/W off and on to clear the reprint.
Insert the form, type information and return.
Insert the next form, press code and repeat print the info should repeat.
If you go to lexmark.com and click your way to publications there is a downloadable manual there.
DickyO
Jan 11, 2010 | Lexmark Wheelwriter 1000 Typewriter
Printer in queue, need to print
It could be a print job that has stalled.
Open the print queue (on the taskbar by the system clock)
and cancel all the documents that are there ,then reprint and see what happens.
Also make sure the printer is plugged in and online.
Apr 21, 2009 | Lexmark X1240 All-In-One InkJet Printer
Reprint
The first thing to do is to set the top margin. Insert the card using the SAPI semi automatic paper insertion, pilling the rt upper bail arm forward, space up or down to the top margin you want, press & hold the code key while pulling the doing SAPI the P/W will spin and reset the top margin.
Type info on card, remove card, insert next card using SAPI, Press code and reprint key and it will repeat.
DO NOT TYPE ANYTHING AFTER A SAPI OR THE REPRINT WILL CLEAR
DickyO
Jul 09, 2008 | Lexmark Wheelwriter 10 Series II...
Reprint
On the L. side of the keyboard there are 3 keys store, play & delete. Press and hold the store key and type an address 01-99 release the store then type info., when complete touch store again.
To print hold play and type the address.
To clear use the del. key.
BE SURE YOUR BATTERIES ARE GOOD OR STORED INFO. WILL BE LOST ON POWER OFF.
DickyO
Jun 10, 2008 | IBM Wheelwriter 30 Typewriter
Re-print full?
The reprint automatically stores as you type. I dont believe it can be turned off, however if you use the SAPI feature it clears and starts over. SAPI Semi Automatic Paper Insertion. When inserting paper pull the rt. upper bail arm all the way forward it will indert paper to preset position and clear reprint memory.
DickyO
Apr 16, 2008 | IBM Wheelwriter 30 Typewriter
Swintek Electronic Office Typwriter Problem
You didn't say what the model is. First be sure the print wheel is properly installed, then turn off the T/W and see if the carrier will move back and forth easily, if not try a little light oil on the shaft that runs thru the carrier (WD40 works well).
DickyO
Apr 13, 2008 | Office Equipment & Supplies
Reprinting Credit Card Slips
Not after you settle it. There is nothing left for it to print off cause they have all been sent off.
Mar 25, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
Lexmark Wheelwriter 10 Series II Typewriter Logo
95 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
