Question about Microsoft Xbox 360 Console
Xbox 360 how do i fix the xbox 360 2 red lights error plz help
  • 37 Answers
2 red lights is a over heating issue. As for fixing, if you don't want to take apart the 360 you will have to send it back to microsoft. If you're okay with taking it apart, replace the thermal paste on the CPU and GPU with Arctic Silver, and then comes the tricky part. The small black screws that are on the bottom of the frame take some fine tuning, usually you leave them fairly loose or not even put them back in at all, only once have I come acrossed where I had to bolt them down as tight as I could get them. You may want to leave the case off until you have finished finding the proper configuration.
Posted on Sep 14, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
I have redone the thermal paste on my 360 and i have turned it on but it just flashes 3 red lights it heats up but wont go to the 2 lights and just keeps flashing the 3 lights even when it has over heated...
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console.
Click here to download repair guide
Dec 14, 2010 | Microsoft Xbox 360 Console
2 red light on
continual long period playing can cause the console flash the 2 red lights? it indicates your console has gotten overheated. The damaged graphics card is another reason for the blinking of 2 red lights on your Xbox 360. This damage happens due to the overheating which is the main culprit behind all the errors and damage to your Xbox 360 console. there are some preventives that should be followed to avoid the 2 red light error occurrence on your 360 Xbox console.
Be careful that none of the ventilation panels are blocked.
Your Xbox 360 is resting on a hard surface, not a soft cloth, bed, sofa surface.
Your Xbox 360 should not be placed near any source of heat.
Your Xbox 360 should be placed in an open location, not confined to a small place.
Getting rid of the 2 red light error is not a very difficult task. You can fix your Xbox 360 console removing the 2 red light error by your own without sending the console to the Microsoft service center and save your dollars and valuable time being spared unnecessarily. For this you need not to have any exceptional knowledge in electronics, and also it is not necessary to have specific, fancy instruments to handle the console for repairing.
The need is to have a professional guide that will give you step by step and detailed information with necessary quality video instructions. While choosing the guide, please be sure that the guide should have minimum cost with money back guarantee. also make sure it is for all errors because some only give solutions to the 3 red lights (red ring of death)
hope this helps
Dec 01, 2010 | Microsoft Xbox 360 Console
My xbox360 will not stop flashing red
Sorry, only answer is to phone xbox and arrange to have repaired. Good news is its all free and should be back with you in 2 weeks.
Sep 20, 2009 | Microsoft Xbox 360 Console
My xbox 360 want turn on HELP ME PLZ
by orange light do you mean 3 red flashing lights on the front? if so you have the red ring of death which is unfixable by someone with no experience, and they should replace that for free as it is a hardware crash which is there fault all the first xbox 360s got it at some stage
Jun 24, 2009 | Microsoft Xbox 360 Console
Xbox 360 two red lights
The fan sounds like it is malfunctioning. Two red lights mean the 360 is overheating. I suggest you don't turn on the 360 until you get the fan replaced as this may damage your 360 more and lead to more problems with the motherboard. If its under warranty then you should get it fixed for free but if not then you might have to pay.
Aug 17, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
One red light bottom right hand corner
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
