Question about Panasonic DMR-ES30 DVD Recorder/VCR
U99 code and tray won't open
When I inserted a recorded disc, the player gave a u99 message and I cannot get the tray to open to take the disc out.
  • Anonymous Mar 28, 2014
    Disc tray will not open or close
    President:
  • 3,130 Answers
Thats a reset code # its on page67 of your owners manual. Unplug the unit for a bit(5minutes) plug in turn on the power then turn off again then back on. If this dosent clear the code, contact panasonic at 800-211-PANA Good luck
Posted on May 10, 2006
Panasonic dmr ez28 fails to record
Thanks Dan, I found a local guy who was wiling to try. He repaired it and I am very satisfied. I don't know why Panasonic and others do not sell dvd recorders with tuners. They could make a bundle.
Jun 08, 2018 | Panasonic Televison & Video
My hk 30 player tray flashes (disc error) with every digital audio disc. help
Often times the tray and pickup lift assembly are related and there is a cam alignment. IF you pulled out with force the tray the alignment may have been upset to where the cam is not completing the lift of the Pickup and if not in the right position the laser will not be able to focus. The correct solution is at a Technicians bench where a new belt could be put in, lubrication that is required and some cleaning will be done.
Jan 21, 2013 | Harman Kardon CDR30 2-Disc CD Recorder
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
My panasonic vhs/dvd recorder DMR-ES30V. DVD will not open and shows error code U99
Error indication u99
After development of the DVD drive and the frame lying under this the cause is nearby a horizontally placed circuit board one Elko 630 uF lid which ones probably lifted presumably is.
Jan 11, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
The player only intermittently recognizes CDs inserted; it does not seem to make any difference whether they are commercial, recorded at home, etc. Sometimes it says "insert disk," sometimes "no disk." ...
A CD tray is usually powered by a rubber strap, the belt can slip through, causing the electronics to miss the input timing, including a microswitch or copper contact which is activated at the closed disc tray so that the laser is focussed to read the table of contents Due to the fact that the spindle motor is activated. And in some players (interchanges there is also a selects witch that can be contaminated. a suggestion to help in the link
How to Fix DVD or CD Player That Won Open
Jun 30, 2017 | Philips CDR950 CD Recorder
Start up u99 message
Hi there, this is what Panasonic say.... The "U99" error code signifies a "general communications failure."
Feb 17, 2008 | Panasonic DMR-E20 DVD Recorder
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Sep 18, 2007 | Philips CDR795 2-Disc CD Recorder
Panasonic DMR-ES30 DVD Recorder/VCR Logo
413 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
