Question about KLH R3100 Receiver
Schematics i have everthing but the thermal paste and the manual schematics. i have done this kind of work, but im thinking without the schematics its pretty much trash.
    President:
  • 1,734 Answers
Ask the schematic finding experts -
They will get it for you.
http://manualfox.com
Posted on Jun 30, 2009
After playing a disc for a few minutes, my Ps3 starts making a noise --constant low whirring sound as if the fan is on overdrive. Any idea as to what might be causing it?
if you have any of these gb consoles these are the first ps3s 20gb 40gb 60gb 80gb.okay these consoles are all dying.see when sony made these they did lead free solders for the cpu and gpu and they used crappy thermal paste on these processors.so now when your ps3 gets to hot or just old it heats up so bad that these solders melt and cpu or gpu come off motherboard its called ylod ur ps3 is in the process of going down at this point u can do nothing for it its pretty much done.u could try replacing thermal paste it may help but i think the damage is to far along to repair if u have the new models like the 160gb slim or 250gb or 320gb then i wouldnt worry about it.
Apr 17, 2013 | Sony Playstation 3 (PS3) Console
Graphic card freezes ul50vt (switching graphic mode)
It sounds like it's starting to over heat pretty bad, or it's building up damage which is pretty bad for just a year. You may need to get the thermal paste within the laptop replaced and the dust cleaned out. Dust traps in heat pretty well, and can do a ton more than most think.
Thermal paste is pretty much this glue for hardware the makes heat transfer between one device and another work at a steady rate for heat reduction.
From what I know, they clean this stuff out for free at places like Laptop X Change :)
I hope this helps. :D
Feb 26, 2013 | ASUS UL50Vt Notebook
This is a question regarding the Intel processor's internal thermal solution. I have a Core i7 870 processor. As a sidenote I've used it a few times to start the computer and it's functioning, but I can't...
If you have already wiped some thermal compound paste fro the processor then I reccommend you to wipe it completly from the heatsink of the cpu and the heatsink itself. The reason to this is that if you plan on purchasing another type of compound thermal paste in which have more conductivilty then you want to get the most out of it. Do not attempt to run your cpu without any thermal compound as you will damage the cpu from overheating.
Jan 14, 2011 | Intel Core i7 870 / .93 GHz processor...
My computer for some time has been randomly resetting
The problem is with the power jack on the computer. You can watch a video of the repair, and it will give you a good idea of what needs to be done:
http://www.youtube.com/watch?v=PBKN6wg8Y30
Someone else mentioned you could get the jack on Ebay for about $20. I don't think you will need a schematic, since you'll know where the jack is and that it needs to be replaced and soldered in. Good luck, hope this helps.
Jun 15, 2010 | Toshiba Satellite A305-S6852 Notebook
I have one red light flashing on my xbox 360. how can i fix it?
If you have a hard drive, clearing the cache might resolve the one red light error. Also, you can try to remove the hard drive and power on the Xbox 360 Console without the hard drive to see if the red light will still occur. If it doesn't appear it is the hard drive causing the error and needs replacement, if it does flash the red light still, it is a hardware failure in your Xbox already.
May 06, 2010 | Microsoft Xbox 360 Console
Overclocking failure!!!
Pull your cooler off the processor and clean off the thermal paste and reapply. Seriously think about putting some bucks into a better way of cooling that monster if you are going to be overclocking. 185 degrees is pretty warm, you probably just baked the thermal paste, replacing it will get the cooling effects back in place.
Dec 20, 2009 | ECS 945P-A (V3.0) Motherboard
CPU over emperature
It sounds like you have a couple of potential problems. First it could be the fan is not working due to failure or not being plugged in properly. Second is that you need to put Thermal Paste between the processor and the heatsink. If you have not done this before, I suggest seeking out a friend that has to help out. There is many kinds of thermal paste and not one is universal. Find out the one that the CPU manufacturer recommends.
May 30, 2009 | AMD Athlon 64 x2 3800 3800+, 2 GHz...
Pc restarts in between the games
is it summer now there? It sounds like heating problems. If you keep the system very cool does it still do the same? (Try opening your side panel, and putting a fan in front of it, blowing into your case, also check to make sure that the fan on the gfx card can spin freely and isn't hampered by dust particles. Also do you have thermal paste? i recommend taking your cpu heatsink off, wiping off the old paste, and applying new paste. I've seen thermal paste get old and then cause this kind of problem. If that still doesn't work, try drivers like bunny recommended. Good luck! :)
Jan 04, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Overheating
I would suggest following the steps in the Maintenance and Service Guide for your laptop, found here on Compaq's website: http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00444244/c00444244.pdf
The relevant information is on page 5-50.
Once you're inside, use a can of compressed air to spray away any dust, etc. inside your machine.
Beware, though: it involves taking the laptop almost entirely apart. If you're daring enough to try it yourself, be sure to keep track of all the screws. You may want to enlist the help of a local repair shop, or a knowledgable neighborhood geek if the prospect of completely dismantling your computer strikes fear in your heart.
Many people try blowing compressed air into the fan from the outside (without taking anything apart). It may clear up the fan temporarily, but the dust would simply be blown further into the machine, something you'll eventually have to deal with.
Hope this helps some.
Javabytes
Nov 11, 2007 | HP Compaq Presario V2000 Notebook
KLH R3100 Receiver Logo
471 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
