Question about Car Audio & Video
UV8 I'm not completely sure how this works, but i commented back on the answer you offered me on my phase liear dvd player made by jensen. if you could offer some more help, that'd be great. thanks
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me". For some reason, I did not receive any notification that you posted back/commented on your original post. Our apologies for any inconvenience.
To your concern, pls confirm if the Jensen's below listed wires are connected to the Subarus' similarly listed wires:
Pls note that there are two (2) wiring versions for the Subaru presented (and possibly several more) depending on the country of assembly/manufacture. Additionally, may I pls inquire if you used a harness/connector adapter, something similar to this? Further, with the use of a DVM, pls check the presence of:
  • +12 on Yellow at any condition: IGN SW off or on, door open or closed, Jensen on or off; and
  • switched +12 on the Red (that is when the IGN SW is either at ACC or ON/RUN) at any condition: Idoor open or closed, Jensen on or off.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for your continued patronage of FixYa.
Posted on Sep 13, 2008
  • Louie  Role
    Louie Role Sep 13, 2008
    If I may add, there are some Subaru GL versions that uses White as the always on B+12 while Black as the IGN B+12. Both may be found in the ignition harness.
How do i override the emergency brake with remote to uv8
Look for dvd hack for that model. I see some on ebay
Jan 05, 2010 | Jensen VM9510 Car DVD Player
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
Nov 26, 2008 | Jensen VM9510 Car DVD Player
Code
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done
This will bypass the video safety.
Thanks for using FixYa - A FixYa rating is appreciated.
Nov 02, 2008 | Phase Linear UDV9010 Car DVD Player
PHASE LINEAR UV8
that model has a adaptor that comes with and you plug that j-link to it i have one.
Jan 20, 2008 | Jensen VM9510 Car DVD Player
Phase Linear UV8
I have same problem with same uv8 but i use remote to activate am/fm then hit setup on rem.enter 543210 and a new menu came up. ( listening for the beep after each 3 is pressed ) select the hammer in upper left hand corner of screen, select brake bypass to on, then hot the X near bottom os screen. this works for me it should work for you.
Jan 11, 2008 | Jensen VM9510 Car DVD Player
Phase Linear UV8
go to setup hit 543210 but hold 0 then turn the bake override on and then hit the X
Dec 11, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
126 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
