Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
No clean dishes
I bought a Kenmore Elite Ultra wash dishwasher under a year ago. It does not clean dishes well leaves white film on inside of dishwasher and dishes are left filmy as well. Food remains on bottom of dishwaster after cycle. My husband has turned up the water temp and water pressure. Nothing works. Have tried numerous soaps as well. This is the worst dishwasher I have had in 20 years. Help The Model # is 665.1312
    Brigadier General:
  • 3,614 Answers
Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve
Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms
There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Detergent cups
Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Posted on Sep 13, 2008
DETERGENT DOOR DOES NOT OPEN DURING CYCLE?
Posted on Nov 03, 2008
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
Oct 13, 2012 | Kenmore Dishwashers
Dishwasher is going on 3.5 yrs old, it worked well for the 1st year but for the last year & half it has been leaving gritty residue on all the dishes. To the point, dishes are being hand washed to...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101//
Mar 22, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
All of a sudden my dishwasher is leaving a white powdery film on the dishes and really bad on the utensils. It had been working beautifully. Is there something inside that might be clogged that I should...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Mar 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My kitchenaid dishwasher leaves a white residue on clean dishes. 4 year old appliance, worked great until 6 months ago. under warranty, service repairman said i was using too much soap( am not). he cleaned...
heatman101
Mar 10, 2011 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kenmore Ultra Wash dishwasher leaves spots on ALL dishes, top and bottom. Changed detergent, same problem.
heatman101
Feb 24, 2011 | Kenmore Dishwashers
We have a Kenmore Ultra Wash Dishwasher Model 15955781. We are now getting a white film on glasses and dishes are not cleaning. What is the problem?
heatman101
Dec 27, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
I have a kenmore dishwasher m/n 665.15895793 (under 10 years old) and its not cleaning the dishes. leaving residue (film) on. if my filter has to be changed , how and where is it located? your help will...
heatman101
Oct 27, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
White film/residue left on dishes
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. Dishwasher Magic is a good choice. works great.
Jun 18, 2009 | Kenmore Dishwashers
New dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Sep 06, 2006 | Kenmore 13869 / 13864 / 13862 Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
552 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
