Question about Acoustic Research AR3 Speaker
AR3 sunfire problems
I've been trying to get a set of AR3 Hi rez Sunfire amp powered subwoofer speakers fixed. One of them blows the fuse on my amp and both of them no longer have the STANDBY power feature, leaving the amplifers on all the time. I can't find anyone with a schematic for the AR Sunfire amplifier or a parts source. I've tried to contact Acoustic Research, Recoton, Thomson as well as several amplifier and speaker repair facilities in Florida with no luck. Any suggestions or help would be appreciated.
  • Anonymous Dec 29, 2007
    I'm having the same problems but with the AR5's.
    If there has been any progress in this matter I'd really appreciate any help finding a schematic for parts order or in house fix.
    Thanks much
    mrwasabihead@gmail.com
  • Michael Edwards
    Michael Edwards Jul 30, 2017
    There is a repair shop Edwards Electronics they are master's at repair. They are on web and eBay.
    New Friend:
  • 60 Answers
Posted on Jul 30, 2017
  • 3 Answers
I had the same exact issue with my AR1s. Found ABTechServices.com that was able to repair it for about $187.50 with return shipping included. Apparently there were a couple leaky caps and some bad resistors. My guess is that when Recoton built these amps, based on Bob Carver's Sunfire technology, they used defective capacitors. These, in turn are probably blowing the resistors and possibly some of the other components.
Posted on Nov 11, 2008
It's not a solution but I have the same problem. I found two transistors shorted in the subwoofer amp, a 2SC3281 and an IRF640. I replaced them but there is still a large dc offset in the output, about 10.5 volts. Without a schematic I'm kind of just fishing.
Posted on Oct 08, 2008
Just wondering if you were able to get any more info on this problem. My house got hit by one of Orlando's famous lighting storms a few weeks ago and along with about $1,000 worth of other equipment, both of my AR5's took a hit. They blow the 5 amp fuse immediately when powered on. So now I'm looking for some help with these as well. Mark
Posted on Aug 15, 2006
    President:
  • 3,130 Answers
Try http://www.simplyspeakers.com. Good Luck
Posted on May 09, 2006
  • Larry  Dillon
    Larry Dillon May 17, 2006
    LMAO If you dont like this place then try this and if you dont get something here sorry . But I order sr parts all the time from here http://www.arspeakers.com orhttp://speakersupply.com/ARinfo.htm
2 Suggested Answers
JigSaw007
  • 157 Answers
SOURCE: Acoustic Research AR1 HiRes subwoofer amplifier
hello sir
Posted on Aug 25, 2008
WHY DOES MY ACOUSTIC RESEARCH AR3 TOWER SPEAKER BLOWS INTERNAL FUSE..FIX?
Check to see who the manufacturer is. The Acoustic Research name was sold a couple of times. I think yours may be Recoton. If so, you may be able to get some help from them.
Aug 24, 2014 | Audio Players & Recorders
No Power
hiya
if u change the fuse inside the actual sub shud power up ok
Rik
Feb 26, 2009 | Sunfire True Subwoofer Mark IV Subwoofer
Blowing the 7.5 amp fuses as soon as I plug the power in.
hello, the reason for the this is because theres a dead short in the unit someware i'd check the diodes first with a multimeter then the transistors then the resistors then the capacitors
regards
shaun
Dec 03, 2010 | Sunfire True Sub MK II Subwoofer
Internal 5 watt fuses keep blowing when I turn on the unit.
hello the reason for that is there's a dead short somewhere it could be a transistors also check the diodes as well but make sure the power's off
good luck
shaun
Oct 17, 2009 | Sunfire True Sub MK II Subwoofer
Sub doesnt do anything while plugged in ( Sunfire mk II)
Some subwoofers can sense the signal on their input and will only start when there's enough signal for long enough time for them to turn on the amp.
Try seting the "subwoofer signal out" on your reciever a bit higher, see if it does the trick, if not, try it with some other source (e.g. an mp3 or CD/DVD player) plugged directly into the subwoofer. If it still doesn't work, there's some other problem with your sub (bad connection inside sub, sub amplifier problems, maybe there's another fuse for the speaker itself, try to check it out).
If it works well with an alternate signal source, the problem might be either in reciever or the signal cable that you use, but could also be something else.
good luck
3rq8 (Triarcuate)
Jul 15, 2009 | Sunfire True Sub MK II Subwoofer
2005 Pontiac Sunfire aftermarket audio system install
You can go to Walmart and in the stereo/speaker department they have dash kits for different vehicles.Just read the box to determine your vehicle. Also, they have amp kits for different wattage amps, but if you had rather buy each item you will need, a Power Wire (to the battery 4g or 8g), a ground wire (to the chassey), a remote wire that should run to a wire from your cd player saying remote (any size is fine), speaker wire (14g or 16g is fine) a set of RCA cables, and if your cd player dosnt have RCA jacks you will have to have a converter.
Jun 27, 2009 | Car Audio & Video
AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Jun 01, 2008 | Acoustic Research AR1 Speaker
Has light but no sound
The first thing to always check first is the fuse. This will probably involve some disassembly but it is alwayst the cheapest fix and a constant issue.
Aug 14, 2007 | Sunfire True Sub Signature Subwoofer
Acoustic Research AR3 Speaker Logo
828 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
