Question about Garden
Countax A20?50 HE Lawn mower oil leak
I have a countax A20/50 HE ride on lawn mower  and there is a oil leak by the rear axel near the wheel. Any advice on how to fix this pls?
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    is it an engine oil leak or hydraulic oil leak?
5 Suggested Answers
  • 246 Answers
SOURCE: I have a Countax K14 ride on mower the cutter deck
Hello ianh_2007:
Usually this Problem is Caused by a Blown Fuse or a Bad PTO Ground.
1-The Following is a Basic File I Made for Checking the PTO (Blade Engagement).
>>The Most Common Cause for this Problem is the PTO Ground. >>A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO.
>>Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire.
>>Clean the PTO Ground and All the Connections for the PTO Wiring Harness.
>>If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
2- >>The Following is a Basic File I made for Setting the PTO Clearance. Any Input is Appreciated. **Some of the Newer PTOs cannot be Adjusted.
>>If you can Get a Blade Style Feeler Gauge between the PTO Magnet and Clutch, then Set the Clearance at .015in. The Newer PTOs have the Same Set Up as the Older PTOs, except there is No Adjustments.
>>I Suggest also that you Rig a 12 Volt Light for Testing the Current Flow to the PTO while Operating the Mower. If the Light Blinks During Operation, then you have a Bad Connection somewhere to the PTO Clutch.
>>If the Light Stays Steady and the PTO Still Kicks in and Out, then it is the Adjustment.
>>You can Also Try Turning the Spring Loaded Adjuster Nuts 1/4 Turn and Operate the Mower. Do Not Adjust Over 1/2 Turn.
>>If you have Adjusted to 1/2 Turn and the Problem is Still Present and you Know the Voltage to the PTO is Steady, then Replace the PTO.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
bbreton
  • 437 Answers
SOURCE: llubrication chart for husquvarna riding lawn
I googled yth2448 manual. A site called ubermanuals.com it came up with an operator's manual you can download.
Hope that helps.
Good Day.
Posted on Oct 26, 2009
SOURCE: i have a countax a20-50.when starting engine with
I have a Countax A2050 and the deck is not lifting when I press the button on the dash, What is my problem?
Posted on Apr 01, 2011
  • 3 Answers
SOURCE: i need a wire diagram for a countax c400h
Whats the issue?
Posted on Aug 23, 2012
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
I have a craftsman revolution riding mower and its having troubles turning to the left. model 247.28933 any ideas??
Check the steering rack cogs r
Are not missing each other as you turn the wheels left if the teeth gap increases as the wheels turn the rack is worn and will need adjusting so the teeth meat better or the rack will need to be replaced this . Part can be quite expensive I had a countax ride on same problem would not turn to the left easily or the steering wheel would just spin. Around but the front wheels did not move until you pushed them by hand 're engaging the cogs on the rack it was nearly £ 596+ vat just the parts needed to repair it
Jun 26, 2016 | Craftsman Revolution 42" Briggs Stratton...
Where can I get a workshop manual for a Countax lawn mower/garden tractor?
I wish I could post the address to your mower, but there is not enough information. Start here:
Countax Tractors
or
https://support.ariens-uk.com/support/home
Dec 28, 2015 | Garden
How do I adjust the throttle/speed on my countax C800 ride on Mower
Making a throttle adjustment for the mower - YouTube
? 23:51
https://www.youtube.com/watch?v=gt0Tmo1p9cM
Apr 8, 2012 - Uploaded by VeeTheAmazingGreek
My old mower was all over the place when running. It would idlehigh then low. I came up with a way to ...Missing: countax ‎c800
[PDF]C SERIES - Pdfstream.manualsonline.com
Nov 23, 2015 | Garden
Where can i get I a new cutting deck for my old countax c300h? I am in Leicestershire and would like it fitted also. Thanks
Sorry to be the bearer of bad news - but it's either ebay, or pay Countax GBP 350 or more. Any C-series deck will physically fit, but power becomes an issue if you over-do it (don't fit a 42" deck if you only have 12HP)
May 05, 2014 | Garden
Mtd removing rear wheels from axel
Be very carefull, if you pull the wheels hard enough the half shaft will pop the circlip on the inside of the gearbox and come away with the wheel, this will then require a gearbox strip down, leave it soaking in penetrating oil and try again.
Jul 11, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
I need a wire diagram for a countax c400h
I am sorry but Fixya has no wiring diagrams for any product.
Mar 13, 2012 | Cars & Trucks
Garden Logo
242 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
