Getting a stainless french door unit installed today. how long will I have to protect my refrigerated and frozen food before the new unit is cold enough? Thanks
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.
Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.
The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
Hello, Thank You for using FixYa. I will be helping you today.The water tank is in the fresh food section remove the drawers and you will see it. Use a hair dryer and heat the tank and lines untill the water starts to dispense.
Thank You and please rate my answer if it was helpful..
From what you are describing it sounds like the air damper is frozen-up & unable to close. This would allow too much cold air going into the refrigerator section. You will need to remove the back panel inside the freezer compartment & inspect the air damper (diffuser). If you see ice & frost built-up in that area you will need to replace the air damper & defrost the ice.
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp. The problem could be the electronic control if
you have one or the mechanical linkages.
the small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement. Sometimes that are only frozen stuck.
LG's bottom mounts have had problems with air leaks in freezer making a iceball right under the evaperator fan actually coming close enough to the fan blades to slow them down or stop them all together also causeing the FFerror meaning the control board is not detecting the normal RPM's you should to keep it cool enough. Suggestion take the back panel off and remove any ice carefully if this be the problem. Make sure all doors are closeing tightly and gaskets make a air tight close.
