Question about Maytag Dryers
I have a maytag perform dryer that I need to install new glides on. How do I do it? I have the new glides already.
  • 943 Answers
Hi thanks for the question Remove 2 screws from the bottom front1each side pull front towards you set to side taking care ouu the wires power off please before you try 4 5/16 screws hold the front bearing remove glides are at the bottom snd of bearing make sure you vacuum all the lint whlie your there clean all venting will work much better thanks The appliance doc
Posted on Sep 13, 2008
Maytag DG4000 dryer. Drum needs a little push to get the dryer going. Without the push the motor hums as though it's trying to go but then eventually quits. Any ideas?
1 phase suggest replace capacitor or wingdings in motor are damaged/ or it could be a bad electrical connection /supply to motor
myself i go for capacitor good luck.
Sep 22, 2016 | Maytag Dryers
We just installed a new Maytag Bravos dryer and right from the beginning it "thumps". The service tech said he may need to replace the drum. On a brand new unit never ran, we are having a...
did you call the factory,if it's under a year it should still be under warranty,you shouldn't have to pay a thing,i would have a problem with that too.
Oct 30, 2010 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Our dryer makes noise (like metal to metal contact
you will need to replace the dryer drum glides on the drum front panel after front panel removal by removing the toe kick panel screws and removing panel this should let you do this w/o removing top cover
Jan 19, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Belt replacment
Here is a diagram from kenmore corp. that should help you out
Maytag Dryer Belt Routing
This is the most common belt routing found on most Maytag brands clothes dryers.
Since you will have everything disassembled to change the belt, this is an excellent opportunity to vacuum out the cabinet to remove dust and lint and perform preventative maintenance on your dryer. When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Dec 04, 2009 | Kenmore 66862 Dryer
Some sort of felt type insulation has come off the inside back of the dryer. I have had the dryer not quite 3 years. Is there some sort of warranty or solution to this. It is tearing clothes.
You need to check your owners manual about the warranty, most likely it just carried 1 year warranty. The felt is what the drum glides on, and if it ripped, the tub will have a gap for cloths to get snagged and rip. The felt glide will need replaced, but, you need to check the edges of the tub for sharp or metal burrs, or it will just rip the new felt. good luck, Shane
Oct 03, 2009 | Maytag MDE308DAYW Electric Dryer
Grinding noise in drum at rear
if your slides went bad, theres a good chance your drum was out of alignment it probably gotr worn on the back side and is now gringing when in the right position......
the good part here is the tumbler carries a ten year warrenty
Sep 26, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag dryer squeaks during cycle
How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
Mar 23, 2009 | Maytag PYE2300AY Electric Dryer
Hello, This is somewhat involved and time consuming, but if you are handy, it can be done. First unplug the dryer then start with the two screws in the hinges of the door and then the door lifts out. Two screws on the opposite side holding plastic spacers. Once these four screws are out the front panel tilts right out. The front panel will come off then 4 more holding on the front tumbler support and air duct. Removed wires from light and dryness sensor and clips holding wires to panels. Pull out the tumbler and removed belt. If your dryer gets a lot of use, then you might want to keep going and replace some more wear items while you have it apart. Remove the two drum support rollers and shafts by removing a nut on the back side of each shaft. Remove snap ring off each old shaft, install new rollers and fiber washers onto new shafts, reinstall snap ring and replaced on brackets with the old nut. Remove tension spring off idler pulley bracket and one screw holding on the bracket. Install new pulley and fiber washers on new bracket and reinstall bracket and spring. Placed new belt on tumbler and reinstalled tumbler. Used drill and bit to drill out pop rivits holding on the two front glides that are attached on the front tumbler support and installed new glides and pop riveted in. Reinstall front support and air duct checking that felt tumbler seal front and rear are in place. Placed new belt on motor pulley and idler pulley. Reinstall front panel.
Dec 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
