Question about Maytag 24 in. MDB6657 Built-in Dishwasher
Keeps running; won't stop
My MDB6657 will keep running and won't stop unless stopped manually or open the door. If I then close the door, it will continue running. I've already replaced the control panel to no avail. Suggestions?
  • gantos Sep 12, 2008
    Thanks for the quick response! I understand your description, but I have yet to discover anything that remotely resembles a relay anywhere other than on the control assembly. I did find some good information on my model here, I am no expert, but I do not see on the schematic where there's some sort of timer relay that would determine how long a cycle should run (assuming that's the problem).
    What about the thermistor? I've read in other forums that some dishwashers will not complete a cycle if the water is not hot enough. This dishwasher is supposed to post-heat the incoming water if it is determined not to be hot enough. Your thoughts?
  • Anonymous Mar 17, 2014
    Every light has come on along the top panel when I switch on and I can't set a programme . It does still work, but won't stop unless I open the door. Any ideas please ?
  • Maytag Master
  • 5,568 Answers
The control panel most likely has control over one or more relays that open or close depending on the programmed action.  The relay need not be the typical electromagnetic kind but could be solid state and produce the same results. It sounds a lot like one of the relays has welded its contacts together (or shorted, in the case of a solid state device) so the control panel and settings no longer have dominion over its actions.
I'm not sure where to look in your machine though.
If you are lucky (well, while being unlucky) there may be a schematic on the housing of the machine that could give you some clues about the location of these control elements.
Posted on Sep 12, 2008
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
www.shopyourway.com > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Dryer keeps running
An IC controller is deffective or can be converted into manual since it stop when you open the door, but only the technician can do this.
Feb 01, 2014 | LG Washing Machines
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
Garage door close but motor keeps running
The close setting limit switch needs adjusted. Once it is adjusted it should work just fine.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Maytag 24 in. MDB6657 Built-in Dishwasher Logo
471 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
