Question about Nikon COOLPIX L3 Digital Camera
Tq..my problem about lens is solve..
New problem coming...after i put on battery inside the camera, the green light turn up but the camera still not working and the LCD screen dosen't show anything. what should i do?
  • 797 Answers
Hello nature pose:
Make sure the battery is charged fully.
If the battery is not fully charged, it may cause this.
If that is not the problem, then the camera needs repair. Repairing this camera may be more than you want to spend. This camera sells for less than $90.00 with everything in good used shape.
It may be that there internal problems or a disconnected or loose cable internally. Failure of electronic parts could cause this problem as well.
I suggest to sell it for parts on a site such as Ebay, if that is the case.
Posted on Sep 12, 2008
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
Feb 17, 2011 | Samsung DualView TL205 Digital Camera
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
My camera will not come on.
hmmm...if the lens in the front is stuck; take the batteries out, charge em (rechargable batteries), put em back in, press the power button once. the lens should come back in only. leave it for a while. hmm...if the green power does that then u need to charge ur batteries again for a really long time. it means the camera will not use the juiceless batteries.
May 13, 2010 | Samsung S760 Digital Camera
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
Camera not coming green light just blinking
Try 4x normal AA batteries. (new)
Also ensure that the memory card cover is firmly closed.
Mar 07, 2009 | Polaroid i733LP Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Camera wont turn on/off
I went to another problem, knowing my camera was stepped on, I messed around with moving the lens part around, barley moving it, and then I tried holding the on/off button and the button to take the pics with, and then put in new batteries and it turned on. I would suggest doing that.
Aug 28, 2008 | Sanyo VPC-S500 Digital Camera
The lens are out, and the camera won't turn on
Having taken apart a number of digital cameras I know they are fiendishly complicated inside. I can only suggest that you double check that the batteries are installed the correct way round and that you try again with new ones straight out of the packet.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Jul 13, 2008 | Samsung Digimax S500 Digital Camera
When i turn camera on shutter closes and lens goes inside, and other way round...
Try the Sony web site technical help. but I feel that there is a main board fault developed here- perhaps time for a new camera try the tech help first though
May 28, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
47 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
