Question about Whirlpool LER5636P Electric Dryer
Dryer not working
On my dryer i was pulling a jacket out and it got caught on the plastic part that when you shut the door will get it ready to start i need to know what to take apart to fix it.
  • sammie_20 Sep 14, 2008
    thanks for the information i checked your post later that day and it came up exactly what i needed to get then i came back to the site today to get item # and go buy part and can't find it so could you please tell me what it is called i can only remember it cost 16.95 Thank you this site has been very helpful.
  • 943 Answers
HI thanks you probably mean a narrow strip of plastic that goes aaround the inside of the mouth of the drum Lift out the lint filter remove 2 star screws with a stot screw driver 2 clips under each corner where top meets front pry upward and lift now top is up on inside of the front each corner 2 screws remove now front comes off plastic ring 2 pieces join together & re instal thanks THEAPPLIANCE DOC
Posted on Sep 13, 2008
I can't open boot as a bag's plastic handles have caught in the mechanism. It's a Ford Focus Zetec 2011. Thanks
The boot mechanism is designed to not be able to tampered with with the boot lid shut, hence cannot be removed when closed..
Can you gain access through the rear seats? if so try heating the bag/mechanism with a blow dryer, might soften and loosen bag, don't place too much heat so that you melt anything..
Aug 06, 2016 | Ford Cars & Trucks
Inglis Gas Dryer... mercy me?
Sounds like what you said. Time for a motor. The motor has an internal overload and will shut the machine off if the motor runs hot.
Good Luck
Feb 26, 2014 | Inglis 6.5 Cu Ft Super Capacity Gas Dryer
Drum won't turn
Is it possible to check the bearing or oil the centre of rotation?
Feb 14, 2014 | Inglis 6.5 Cu Ft Super Capacity Gas Dryer
The dryer will start and then shut off apparently randomly and need to be restarted
Most likely it's the door switch. Start it then pull around the edge of the door and see if it stops. A plastic or metal tab may need to be bent back into shape or the switch is coming loose behind the door panel.
Nov 03, 2013 | Dryers
I wish to wash my Marmot down jacket- what products should I use and what is the best way to wash it?
you can buy specific detergent for down based products to clean and retain the insulation properties of teh jacket. I use NikWax down wash which works really well for my mountain hardwear down jacket. Follow the instructions which are usually:
put washing machine on clear cycle to flush all residue detergent out of the machine, use 1-2 capfulls of down wash and wash on a low heat 30-40 degrees. Then either air dry or my preferred method is to put it in the dryer by itself on a low heat with some clean tennis balls in the dryer - hey presto lovelly and clean jacket ready to go out and get mucky again
Jul 10, 2011 | Marmot Mountain Down Jacket
My GE Harmony dryer has power at terminal but when press power button no power what could be the problem? all wires are connected no shorts.
the door must be shut to start the dryer check the door switch some have small plastic tang that pushes the switch in when the door is shut if that tang is broken then no switch no start
Apr 18, 2011 | Dryers
An ring fell out of jacket pocket while jacket drying, can see ring when pull out lint catcher. ring located in "dryer pipe" opening next to a rubber gasket in the front of the dryer unit. How...
You will need to remove the hinges, they lift up and out once screws are removed, the the two white plastic pieces with the screws these are for door reversal, then the front panel lifts off. Good Luck Tim
Nov 06, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Seems to be ppower, cheched fuses where the box
this is most likely caused by the door switch. if the door is not closed, the dryer will not turn on, period. you will have to try to jump over the 'possibly bad' switch. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. use a piece of wire to connect them or just tape the metal ends together. this will bypass the door switch. make sure all metal parts of the wires are covered to prevent a short on the metal walls. be sure the now loose wires will not get caught on anything, like a rotating drum. close the lid most of the way. turn on the breaker and try to operate the dryer. if it now works, replace the door switch. be careful, opening the door will not shut off the dryer now. good luck
Nov 04, 2009 | Maytag MDE2600 Electric Dryer
Suddenly stopped working will not start at all any setting
assuming that the circuit breaker or fuse is not blown, this is most likely caused by the door switch. if the door is not closed, the dryer will not turn on, period. you will have to try to jump over the 'possibly bad' switch. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. use a piece of wire to connect them or just tape the metal ends together. this will bypass the door switch. make sure all metal parts of the wires are covered to prevent a short on the metal walls. be sure the now loose wires will not get caught on anything, like a rotating drum. close the lid most of the way. turn on the breaker and try to operate the dryer. if it now works, replace the door switch. be careful, opening the door will not shut off the dryer now. good luck
Nov 02, 2009 | Kenmore 62802 Electric Dryer
Start Button will start dryer but won't stay on!
pull end caps off just grab at top of plastic and pull towards you remove the 2 screws underneath lift console up and roll back next to timer is a small control bd to right of that are 2 relays 1 with red wires for element and 1 with blue wires for motor first try switching the relays they are identical and will work for either 1 ..try if works replace relay ..if still not working suspect control bd
Jul 01, 2008 | Kenmore 63952 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
