Question about Zanussi WJD1457W Front Load Washer / Dryer
Broken interior Door catch
Hello! I ahve broken the door catch on my Zanussi WJD1357S which I guess is in the similar series. It has broken inside the machine and I need to know how to fix it, I'm at a loss! I can't even see how I shoudl access this area! Many Thanks Lynne
  • Lynne Parker May 15, 2006
    THANK YOU SOOOOO MUCH - I never believed I would be able to fix it through this website, now I'm hooked!!!!!
    I am very grateful!
  • 641 Answers
You should open machine's upper panel (release 2 screws in the machine's back and slide the cover out) and then you will have an access to it. You should buy a new door catch and replace the broken one. Be aware that you should disconnect machine's power cable before doing it. Good luck
Posted on May 09, 2006
Door does not close zanussi zwf 1632w
The catch is broken that locks the door
Jan 10, 2018 | Zanussi Washing Machines
The left back door won't open from the outside, it will only open from the inside.
Sounds like the door linkage from the outside handle to the door catch is disconnected / broken. Recommend take off door interior trim and have a look at the little metal linkages. Haynes manual for your vehicle should show how.
Aug 25, 2014 | 2010 Kia Sorento 2.4
Broken door catch
First turn the micro door upside down and shake it this may dis lodge it make sure its unplugged and rotating table is removed.If you can see the piece try tweezers or needle nose pliers but again make sure it is unplugged during any handling period!
Second UN plug the device remove its cover with phillips driver or what is needed after it is removed go to the safety switch where the piece is located remove it and shake the piece it may come out if not just replace the complete safety switch
Apr 06, 2012 | Zanussi ZM24ST Microwave Oven
Drivers door wont open
If it were me , I'd remove the inside door panel and take it from there. It may be that you can pry open the lock mechanism with a screw driver or a similar tool, allowing you to open the door - which obviously you must do. Even that, though, will not solve the cause of your problem. You may wind up at the dealer.
Aug 19, 2017 | 1986 Ford Tempo
How do i open the door on hotpoint WD440, latch is broken?
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Zanussi Tumble Dryer - TD 4112 -Door Catch Assembly/Repair The plastic catch broke and I have bought a replacement however I can't work out how to put the pin, spring and catch back together. Any help...
Jason, I have the same problem... the catch on my Zanussi dryer has broken. I've ordered a spare part... and remembered how I took the thing apart.
I'd have to show you... it can't be put into words. LOL
Hopefully by now you've figured it out. (Just seen the date you posted this).
~ Franka ~
Aug 31, 2009 | Zanussi TD4112W Electric Dryer
Hi We have a Zanussi Turbodry and when i tried to open the door it wouldn't move and i have now broken the handle off!!! How do we open the dooe?? Thanks Lynsey
Get a thin screwdriver and poke it in between the door frame and the front of the washer where the door latches in, push hard and see if it will release that way..
If no go, then remove top of washer , and with a long screwdriver or similar try to release the door catch from inside the front of washer, you may have to lever it open, and possibly break the door lock in the process.
There really is no other way of releasing door.
You obviously will have to replace the whole door handle assy, and the door lock.
Plz rate my solution.
Thanks.
Jan 18, 2009 | Washing Machines
I have a 1998 BMW 528 I. The drivers side door latch will not catch. So door will not close or lock
Wit the door open, using a srewdriver, use it to throw the catch, then see if the latch locks into position. if it doesn't then a new catch will be required as the locking latch spring inside the latch would have broken
Dec 06, 2008 | 1998 BMW 5 Series
Interior Door catch broken
May 09, 2006 | Zanussi WJD1257S Front Load Washer
Zanussi WJD1457W Front Load Washer / Dryer Logo
245 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
