Question about Acer AL1916W 19" LCD Monitor
This is embarassing
I have an Acer 19" LCD, circa 2005. Recently it stopped working, and I'm reasonably sure it's a faulty capacitor, certainly somewhere in the power supply; nothing on screen, the green light is strobing very fast (and continues for a few seconds even when the main power is removed) and there's a faint ticking sound heard in the back. Now - I can work that out, but I cannot work out how to take the back off - there are no screw holes! There's two small ones on either side of the switch panel, and the ones holding the stand to the monitor itself. Aside from that, nothing. I'd rather not hack it to bits in case it's a simple problem. HELP!
  • Steve1961 Sep 12, 2008
    Out of frustration I poked the screwdriver through the hole and the the back started to pop off. It's pressed on and some fragile little plastic pieces broke in the doing. Oh well, it wasn't working before, so no great loss.
    Scholar:
  • 55 Answers
Not certain for this monitor, but most LCD monitors seem to have a bezel that slides upwards to remove.
If removing the small screws allows you to lift the bottom edge of the bezel, then I'm pretty sure that's how it will work - put it face up on a desk or your lap with the screen upwards, lift the edge fo the bezel a little and push the two nearest corners away from you at the top (the left and right bottom corners as you would look at the monitor on your desk). The bezel should slide maye an inch, come off the clips and then lift right off.
Hope that helps.
Posted on Sep 12, 2008
  • Ugifer Sep 12, 2008
    PS I think your right about the capacitor issue - my monitor (not acer) recently gave similar symptoms and was cured with a hand-ful of 105'C electrolytics.
    Good Luck!
Lcd acer al1917w dispay problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Repair Kit ACER AL1917W ILPI 031 LCD Monitor Capacitors Not the Entire...
Apr 05, 2014 | Acer Ferrari Computers & Internet
Acer v223w on and off
You could have a faulty power supply. If the capacitors have a blown (deformed top) then they are faulty. Replacing these capacitors with new ones may fix the problem provided nothing else is faulty. Make sure you replace them with the same voltage and capacitor rating.
Nov 30, 2012 | Acer V223W LCD Monitor
I have a gateway FPD1975W tft lcd Monitor. It will not power on at all. I took the power cord from an exact same working monitor and put it in this one and it still will not power on?
Faulty power PCboard. Reasons and the exact problem may vary. Main components to check: The fuses, the stabilizing capacitors on the low voltage, the impulse transistor, the optron and the pulse width modulator (PWM) IC.
Jun 15, 2010 | Gateway FPD1975W 19" LCD Monitor
My monitor takes forever to load. It only started to happen recently no more then a week or 2. Every time I turn on the monitor the green light blinks several times. After it stops the monitor just keeps...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | Acer AL1912 19" LCD Monitor
My monitor takes forever to load. It only started to happen recently, no more then a week or 2. Every time I turn on the monitor, the green light blinks several times. After it stops, the monitor just...
Most likely caused by defective capacitors in the power supply. This is quite a common problem.
If you have some electronics skills, you may be able to change them yourself - look for bloated, otherwise deformed or leaking capacitors, typically in the 470u - 1000u / 25V range. Replace them with 105°C rated low ESR types of the same value and voltage rating.
If you don't know what I am talking about, bring it in for repair (if it's still worth it...).
Mar 19, 2010 | Acer AL1912 19" LCD Monitor
My lcd monitos blinks random intervals
If that model has no external power supply then the supply is internal and some capacitors are failing. The problem will worsen until the display will not work at all. It's a fairly common problem with that type of monitor. The capacitors are cheap, and not too difficult to desolder and replace. The hardest part sometimes is getting the darned thing open. I had just recently went through this process with an AL1917. Seems like there were four 470 mfd/25 volt and two 220 mfd/25volt. Be sure to use the hi-temp type caps (105 deg C)
Hope this helps.
Dec 16, 2009 | Acer AL1916W 19" LCD Monitor
Acer al1916 lcd flat panel display turns on but no picture.
yeah, it's fixed, answer already posted, just typing this to stop the site from notifying me...
Dec 15, 2009 | Acer AL1916B 19" LCD Monitor
Acerx193hq monitor keeps turning off only just started doing it purchased march 2009 have to press menu on monitor comes on then goes off again
Hi
Capacitors going bad are causing this problem. Call Acer and let them know. It may still be in warranty, if not it should certainly qualify. Parts age in everything electronic but LCD monitors should have at least 2 years of use before parts begin to change value.
Thanks
Jul 21, 2009 | Acer AL1916W 19" LCD Monitor
Acer al1916b high pitched noise when on standby.
Sounds like you could have an open ground? Also might check the wiring to see if you have a faulty connection in VGA cable or power supply cable
Jul 24, 2008 | Acer AL1916B 19" LCD Monitor
Monitor will not power on....
I just repaired one. Symptom was no power at all. When I plugged it in, I could hear the switching supply making a noise, like it was trying to turn on. I opened it up and It ended up being 2 capacitors in the power supply section. I seen the tops were swollen, they were 1000uF 10V. They were for the 5volt power section I believe.
I think they were C824 and C825. I removed both of them and replaced them with one 2200uF 10V cap. I powered it up and it works now.
Oct 24, 2007 | Dell UltraSharp 1905FP 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
109 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
